Problem advise
cardiff996
Problem advise
Post by cardiff996 » Sat Dec 31, 2011 4:49 pm
Bongo is currently out of action - Diesel 2.5 - R - Reg.
Its currently being fixed at the garage but having trouble. There is no fuel going to the injectors? Fuel lines have been checked and Solenoids for the fuel pump have been changed.
No luck as yet, and they plan to connect it up to a lap top to fault find.
Anyone else had similar problems or any suggestions?? Just before it finally broke down it was not revving past 2K RPM, but engine would start etc.
Cheers as always gang
Re: Problem advise
Post by francophile1947 » Sat Dec 31, 2011 4:55 pm
Assuming the fuel filter has been changed, have they checked the banjo strainer/filter?
Re: Problem advise
Post by Northern Bongolow » Sat Dec 31, 2011 6:04 pm
i dont usually talk much sense, but here goes.
re the low revs. if its the later turbo,(variable pitch blades) has it gone into limp mode etc.
longhaul8
Re: Problem advise
Post by longhaul8 » Sat Dec 31, 2011 7:24 pm
I normally go into limp mode after a bottle of single malt :lol: :lol: :lol: or so the wife tells me :oops: :oops: :oops:
Re: Problem advise
Post by mikeonb4c » Sat Dec 31, 2011 11:25 pm
longhaul8 wrote:I normally go into limp mode after a bottle of single malt :lol: :lol: :lol: or so the wife tells me :oops: :oops: :oops:
Yea yea I know, she has to tell you cos you can't even remember ha ha. My problem is the same as my AFT: my mechanic says I should raise it regularly, or it might seize up from lack of use and let me down when I need it to work. :-(
cardiff996
Re: Problem advise
Post by cardiff996 » Sun Jan 01, 2012 1:16 pm
Thanks for info.
Cleaned and replaced the filters myself before it went into the garage.
I dont think it has gone into any safe mode as it didnt start at all, and there is no fuel feed at all to the injectors.
Re: Problem advise
Post by Simon Jones » Sun Jan 01, 2012 1:51 pm
I know this may seem like a daft question, but are you 100% sure there is plenty of fresh fuel in the tank? Bongo fuel senders are notoriously unreliable....
cardiff996
Re: Problem advise
Post by cardiff996 » Sun Jan 01, 2012 5:09 pm
Yep tank is half full.....I think!!!
Jipsup
Re: Problem advise
Post by Jipsup » Tue Jan 03, 2012 1:24 am
just a usefull tip i spent ages on mine , till i found there is a filter in the deasel pump
if you take of inlet pipe and make a fine hook put this down hole and you will find a spring under this is the smallest thimble filter if blocked it will cause lack of fuel or if partly blocked will cause stuter at higher speed
hope this helps , it cost me £200 before i found this
ray
Re: Problem advise
Post by francophile1947 » Tue Jan 03, 2012 12:19 pm
Jipsup wrote:just a usefull tip i spent ages on mine , till i found there is a filter in the deasel pump
ray
That's the banjo filter that I mentioned above.
