Hi Folks.
Do you really need to take the whole of the rear door internal linings, door handle, pull handle, plastic protection, whole light panel and number plate panel and side lights off to replace a bulb? Am I missing something simple here? How hard can it be? Gave up after I started to lose feeling in my hands and was dropping nuts, screws etc into 6" of snow. Has anybody replace one before? (These are not the rear light clusters I am talking about, but the rear reflector lights either side of the number plate in the actual tailgate) Any pointers greatly welcomed.
David.
Replacing rear tailgate bulbs. New shape 2003.
MountainGoat
Re: Replacing rear tailgate bulbs. New shape 2003.
David, this has come up before. See this thread:
http://www.igmaynard.co.uk/bongo/forum/ ... bs#p489233
Tony
PS: use the search facility you lazy so and so.
Tony
MountainGoat wrote:David, this has come up before. See this thread:
Tony
Less lazy and more disbelief Tony. I cant believe its such a faff just to change a ruddy bulb!
ps Happy new year mate.
- Simon Jones
More info http://www.igmaynard.co.uk/bongo/forum/ ... =+tailgate & a diagram: http://lushprojects.com/bongopartsmk2/c ... 3of03.html
There are only 2 sidelight bulbs in the tailgate & they are supplementary to the main clusters so it may be worth considering fitting good quality LED replacements if you don't plan on taking the panel off again. Not a great design from Mazda, but I used to have an Audi A4 & to change any bulb you would have to remove the entire light unit inc the head light. In fact, the glovebox manual said you had to take the vehicle to a main dealer to change a bulb. I used to get Audi Assist to come out & do it for me
Thanks for the links Simon. I had already looked at the lush projects diagram to check if i was missing something simple...... but alas no. i dont recon all the nylon clips and scrivets will take removing too many times, so LED may be the way to go....... or just disconnect them both, but i do like the extra illumination they give.
hey ho..
iirc are the bulbs 501 type and are accesible from inside, if you remove the tailgate inner panel. they're tuck away right in the corners in push n twist fittings and are a pain to get in and out
Julian
Julian
Thanks Jullian. I could not work out that they were 'push n twist', so will have another go when my hands are a little less cold. I was finding it hard to believe that I had to take the whole 'light cluster' off the tailgate to change a bulb321Away wrote:iirc are the bulbs 501 type and are accesible from inside, if you remove the tailgate inner panel. they're tuck away right in the corners in push n twist fittings and are a pain to get in and out
Julian
cheers
David.
