Suspension bottoms out!
jimpearceuk
Post by jimpearceuk » Wed Jul 13, 2011 10:47 pm
With a bike rack sat on my tow bar I was experiencing lots of suspension bottom outs, on the motorway its not nice! I duly booked in and had the rear shocks replaced and to be honest its not made much of a difference :(
I have read before about pump up systems but cant find anything on these - or do I have another problem? I also had the drop links replaced which just leaves the springs.
Even without the bike rack a speed bump slightly quicker that it should be will bottom out easily.
Just received a new 4 bike rack, which is heavy even in the absence of a bike so I need to solve this now.
Appreciate your views!
Jim
Re: Suspension bottoms out!
Post by Northern Bongolow » Wed Jul 13, 2011 10:51 pm
springs. get some off a tinny.
or do what i did which was make some same size but softer hitting bumpstops.
Post by missfixit70 » Wed Jul 13, 2011 11:19 pm
I went for Airlift air assistors from Matt Savage , as have loads of people, gives you some control of the ride depending on pressure, work great with fully loaded backbox & bongo, no more bottoming out & wallowing.
http://www.igmaynard.co.uk/bongo/forum/ ... ft#p421585
http://www.igmaynard.co.uk/bongo/forum/ ... 3&start=15
Plus there's a factsheet in the members area.
If I was going to replace the springs to improve the issue of bottoming out etc, I'd go for new tbh, used ones from a tinny MAY have less wear/strain than those from the heavier aft, but is a tinny more likely to be used as a people carrier than a camper, thus carrying around a load of weight anyway? :wink: Just my opinion :wink:
The Great Pretender
Post by The Great Pretender » Thu Jul 14, 2011 1:25 am
:lol: :lol: :lol: well I managed to kill hat thread didn't I........... :lol: :lol: :lol:
As for springs, it's late, I'm knackered from long hours in the workshop re manufacturing parts for a member so forgive me for not researching.
Wouldn't the tintop have softer springs and anti roll bars as the extra weight with a pop top has a lever arm effect acting on the suspension? Or is that why the tintop corners so well?
To infinity and beyond
A1tony
Post by A1tony » Thu Jul 14, 2011 9:50 am
As per the other comments,
Just fitted mine with Air Lift 1000 kit from Matt Savage. Its the best 100 quid I have spent and cures all your problems unless the springs are shot. I have an LPG tank and cycle rack hanging over the back axle, so I was suffering just like you.
Remember to fit them upside down though. its much easier. (also see the fact sheet...)
regards
Tony
apole
Post by apole » Thu Jul 14, 2011 1:19 pm
Check your rear shocks too, I fitted the airlift before changing these. The shocks made a big difference, as did hte air lift
jimpearceuk
Post by jimpearceuk » Thu Jul 14, 2011 2:09 pm
cheers all - air lifters it is then - the shocks are brand new and it has made a slight difference but not a world of!
Jim
jimpearceuk
Post by jimpearceuk » Tue Aug 30, 2011 11:33 pm
Airlifters fitted, a different motor - I cannot believe the difference, running them at 20psi with the van full and 3 bikes on the back and you really don't feel loaded up any more.
Impressed, great advice thanks!
