Is this the sound of a belt slipping?
dvisor
Post by dvisor » Fri Sep 03, 2010 1:28 pm
The bongo developed an annoying squeal while we were away. I'm assuming its a slipping belt... and it sounds like this (download about 190K):
https://docs.google.com/leaf?id=0B_YjpO ... ey=CKqn210
can anyone confirm?
We also had trouble with our leisure battery - which I guess could also point to the alternator belt (or it could be unrelated).
Two tonne tin drum
Re: Is this the sound of a belt slipping?
Post by haydn callow » Fri Sep 03, 2010 3:33 pm
No 1 manifold stud broken.....easy fix (my best guess as the link failed)
dave_aber
Post by dave_aber » Fri Sep 03, 2010 4:41 pm
Sounds like what I expect No1 stud to sound like - well, it's what mine sounds like and I haven't had time to check yet. Next job on the list I guess!
Image...Image
dvisor
Post by dvisor » Fri Sep 03, 2010 4:45 pm
Maybe this link will work instead (it sounds uncannily like the noise the demon made in the 1950's film "Night of the demon" :shock: )
https://www.yousendit.com/download/UFVx ... VWxjR0E9PQ
I had a Bongo garage check the No 1 manifold stud about a month ago, and it passed muster then (they also replaced the belts). I did push the Bongo pretty hard over the last couple of weeks up and down the Pyrenees, though.
Two tonne tin drum
dave_aber
Post by dave_aber » Fri Sep 03, 2010 5:00 pm
Hmmm.... Mine sounded fine until I went over the Alps twice. :oops:
Image...Image
flipflop
Post by flipflop » Fri Sep 03, 2010 7:50 pm
Just had my No1 and 8 stud done with replacement gasket etc, squealed when setting off and when giving it a bit of welly !!
Now no squeals hurrahhh
Post by Doone » Fri Sep 03, 2010 8:37 pm
Was the engine hot or cold when you recorded the sound?
mister munkey
Post by mister munkey » Fri Sep 03, 2010 8:43 pm
It would help if you could do the same again but with a couple of blips on the throttle.
I caught the sound on the second link, it does sound like it could be a stud problem but its more dectectable with a bit of welly. The noise changes to a strangled budgie kind of sound under load.
2sticks
Post by 2sticks » Fri Sep 03, 2010 9:22 pm
Sounds very much like belt squeek, not necessarily belt slip.
Get a sqeeze bottle full of water and spray on the belts while
ticking over. If it stops squeeking immediately it's the belts.
dvisor
Post by dvisor » Fri Sep 03, 2010 9:40 pm
Thanks all for the replies.
We were supposed to return via the Alps, but we're now saving that for next year.
It was cold when I recorded it. In fact, I think I was only aware of the noise at the start of each journey.
I'll do another recording tomorrow and give it a few revs.
I'll try that.
Two tonne tin drum
Post by Northern Bongolow » Sat Sep 04, 2010 3:40 am
sounds like a pulley rattling to me :shock: .
i would slacken all the belts and check the pulleys carefully.
Post by haydn callow » Sat Sep 04, 2010 8:51 am
Now I've heard it ..It dosn't sound like a manifold stud or belts....I will go with ADY above
dvisor
Post by dvisor » Sat Sep 04, 2010 9:33 am
If it's a pulley rattling, is that a more serious issue (I'm completely non-mechanical)? Am I best not driving it until its sorted - or can it wait until I'm able to get it to Bellhill (there's a good garage round the corner from me, but its not a Bongo one)
Two tonne tin drum
Post by haydn callow » Sat Sep 04, 2010 10:15 am
If it's a pully rattleing...I would get it recovered to a garage....If it flys off it could do more damage...Or get a mobile mechanic to check it out.
Post by rita » Sat Sep 04, 2010 10:51 am
Sounds like an alternator bearing.
Cheers..
