No Oil pessure light
maviczap
Post by maviczap » Wed Jan 26, 2011 4:51 pm
Ok, having changed the oil & filter yesterday, it dawned on me that the oil pressure light wasn't working and hasn't been working for a while.
I've done the obvious and changed the bulb over.
Where's the oil pressure sender on the engine & is there anything else I need to check.
Re: No Oil pessure light
Post by g8dhe » Wed Jan 26, 2011 5:04 pm
Post by teenmal » Wed Jan 26, 2011 5:30 pm
maviczap wrote:Ok, having changed the oil & filter yesterday, it dawned on me that the oil pressure light wasn't working and hasn't been working for a while.
The oil pressure switch is 18501.
http://www.lushprojects.com/bongopartsm ... no=.html#4
Post by Northern Bongolow » Wed Jan 26, 2011 5:33 pm
and a little tip, its below the oil level so if removing it drain the oil first,unless you have a thin finger spare :lol: #-o . may be worth checking the lecky connection is good first. the deep large socket needed may also cost more than the new sender.
Post by teenmal » Wed Jan 26, 2011 5:56 pm
Northern Bongolow wrote:and a little tip, its below the oil level so if removing it drain the oil first,unless you have a thin finger spare :lol: #-o . may be worth checking the lecky connection is good first. the deep large socket needed may also cost more than the new sender.
Hi Ady,
The oil pressure switch is on the crank case,the oil is in the sump.
maviczap
Post by maviczap » Wed Jan 26, 2011 7:57 pm
Thanks guys, but as I understand the light on the dash serves two functions. One is for oil pressure & the other is low oil level? Have I got that right?
Could it be a fault on the dashboard.
I've still got the fault with the glow plug light not going out.
So could the oil pressure light not working be a fault in the dash, a short circuit?
Is there anyway to test the circuits?
Post by g8dhe » Thu Jan 27, 2011 1:22 am
The circuit is here for the 1997-1999 diesel;
That shows two sensors C1-06 and C1-07
which relate to the two Lush project diagrams
For the Oil level 10-7301 http://www.lushprojects.com/bongopartsm ... o=.html#17
For the Oil pressure 18-501 http://www.lushprojects.com/bongopartsm ... no=.html#4
Post by Northern Bongolow » Thu Jan 27, 2011 5:21 am
Hi Ady,
:lol: :lol: i know where it should be (the oil) but, when i removed item 18 501 in geoffs link,i got wet :lol:
but i admit to not knowing about the other one, 10 7301 #-o .
go on be a devil---try it. :D :wink:
321Away
Post by 321Away » Fri Jan 28, 2011 4:27 pm
Sure you havent unplugged the pressure sensor as its located right byt the filter, it has a connector by the alternator and push on to the sensor, all in the vacinity of the oil filter.
Julian
maviczap
Post by maviczap » Fri Jan 28, 2011 10:25 pm
321Away wrote:Sure you havent unplugged the pressure sensor as its located right byt the filter, it has a connector by the alternator and push on to the sensor, all in the vacinity of the oil filter.
Julian
I'll have a look tomorrow :D
