A while ago I had to carry out some work to get the old bus through the MOT. Part of this involved changing the 'o' rings in the fuel pump as per the bongo fact sheet.
Cured the fuel leak and passed the test but left me with a different problem that as yet, I have not been able to cure
The old girl seems now to be as flat as a pancake! There seems to be no go in her when accelerating. Between 40 and 50, if you engage the kick-down, it drops down ok, but almost like its dropping to second and not third. Loads of revs but no increase in road speed. The change between third and fourth seems to be very close together as well.
Before I did the 'o' rings, she had loads of grunt for a big old bus and would change gear perfect. Now, you have to almost feather the throttle to get the gear changes to happen, indeed changing from first to second almost requires you to feather the throttle otherwise it just seems to stay in the lower gear and rev like mad.
Not sure what the bit of pump that was removed and re-fitted does and if it could cause the problems I am getting or not? Only other area that may have been disturbed is where the MOT guy had his inspection light passed up through the sump cover by the gearbox end whilst looking to see if the fuel leak had been done.
Help! its driving me mad!
Adrian
