Thermostat Gasket diesel
SimonT
Post by SimonT » Fri Mar 20, 2009 11:37 pm
I have replaced the thermostat in my bongo, due to overheating, but it now appears that the housing is leaking. I think this is from the joint.
I would have thought that there was a gasket for a diesel, but cannot seem to find one, and one was not fitted when I opened the housing.
Any advice?
Simon from Exeter
Bongotastic !!
The Great Pretender
Re: Thermostat Gasket diesel
Post by The Great Pretender » Fri Mar 20, 2009 11:45 pm
There should be a rubber seal around the outside of the stat.
To infinity and beyond
SimonT
Post by SimonT » Fri Mar 20, 2009 11:53 pm
Fantastic pic The Great Pretender !!
Yes, I fitted the thermostat with the rubber seal.
MaybeI have to tighten it up a bit more.
Simon from Exeter
Bongotastic !!
The Great Pretender
Post by The Great Pretender » Sat Mar 21, 2009 12:03 am
The seal sits in a recess,if it isn't fully in it it will leak. Do you know how to bleed the cooling system correctly?
SimonT
Post by SimonT » Sat Mar 21, 2009 10:42 am
Yes, I am fine with the cooling system bleeding.
I will have to check that the seal is seated properly - hmm another session with the cooling system, at least its a nice day for it. :D
Thank you for your help
Simon from Exeter
Bongotastic !!
Post by mikeonb4c » Sat Mar 21, 2009 11:01 am
I nearly installed mine upside down :oops: Presume you are OK on that front?
SimonT
Post by SimonT » Sat Mar 21, 2009 9:56 pm
The problem is sorted now thanks guys. I used a touch of Hylomar Universal Blue Gasket Sealant and checked the seating of the stat. the leak has gone. Spent 2 hours bleeding the system. I am hoping my heating issue has been resolved. I have replaced the radiator and the stat now.
One thing i noticed was that the scavenge fan just in front of the engine did not start, despite hearing the radiator fans starting during the bleeding session. I wonder if this is contributing to my overheating problem.
Simon from Exeter
Bongotastic !!
Post by mikeonb4c » Sat Mar 21, 2009 10:15 pm
SimonT wrote: One thing i noticed was that the scavenge fan just in front of the engine did not start, despite hearing the radiator fans starting during the bleeding session. I wonder if this is contributing to my overheating problem.
I don't think so, esp. since the weather isn't even hot. Its really for cooling the engine bay and not as a critical element in preventing overheating I suspect. For me, suspicion would fall next on the radiator as being clogged.
SimonT
Post by SimonT » Sat Mar 21, 2009 10:37 pm
Ok, thanks Mike, I changed the rad about 2 weeks ago for a new one. I have bled the system and sorted the stat, but I haven’t had a chance to take it for a test drive to check the overheating probs yet. I will do that tomorrow and post the results. I have a good hill about 5 miles from me on a dual carriage way that really tests the engine at speed. It is so annoying seeing the needle go past the 12 O' clock position, but fingers crossed :D
Simon from Exeter
Bongotastic !!
Post by mikeonb4c » Sun Mar 22, 2009 1:13 am
SimonT wrote:Ok, thanks Mike, I changed the rad about 2 weeks ago for a new one. I have bled the system and sorted the stat, but I haven’t had a chance to take it for a test drive to check the overheating probs yet. I will do that tomorrow and post the results. I have a good hill about 5 miles from me on a dual carriage way that really tests the engine at speed. It is so annoying seeing the needle go past the 12 O' clock position, but fingers crossed :D
Ah :oops:
Well lets hope that new rad. and new thermostat plus correct bleeding will get it settled [-o<
Good luck - keep us posted
SimonT
Post by SimonT » Sun Mar 29, 2009 5:38 pm
Yes, thanks it did sort it.
It took more than one session of bleeding though. Cant really emphasise enough how important it is and how important it is to do it correctly.
Simon from Exeter
Bongotastic !!
Post by mikeonb4c » Sun Mar 29, 2009 9:01 pm
SimonT wrote:Yes, thanks it did sort it.
Excellent - just in time for Spring and Summer \:D/
