Reading other threads on here it seems that if the gasket goes the head usually goes too.missfixit70 wrote: continued from this topic http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=34527
The symptoms I have are that when the engine warms up, that air is forced into the cooling system. At some stage this has been "fixed" by removing the stat and thus keeping the engine cold. I discovered the problem when I fitted a stat. I have had to remove it again to keep running.
Has anyone had the gasket go without the head? And what were the symptoms.
BTW the fact that it does run quite reliably with the stat removed may be a good "get you home" method if your head goes whilst on holiday.
Dave
