I'm not against the fitment of a Coolant Alarm I'm just looking to explore new avenue's we can take.
Any input on this could be of great assistance to one and all.
Thank you.
Duncan.
Okay, you've got a mid engined vehicle anything up to 15 years old, with a radiator, 2 heater matrixes, 17 hoses, numerous metal pipes & connections & a cast iron block with an ally head. Several weak points there already, water pump & thermostats fail, mixing of incompatible jap/uk spec coolants http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=28754 (possibly leading to sludging, jelly like "snakes" & chemical corrosion weakening the head) fan sensors, fans, etc.dandemann8 wrote:Hi, why do so many Bongo owners fit a coolant alarmIt may give you an early warning that a problem as occurred but surly there is preventitive action prior to fitting a Coolant Alarm that we can take
I've heard it may prevent HGF and a costly bill down the line but what are the exact weakness's of the Bongo engine that we can maintain to keep our babies on the road i.e replace hoses at regular intervals say 2 to 3 years, check your oil and water levels and frequent servicing etc....
I'm not against the fitment of a Coolant Alarm I'm just looking to explore new avenue's we can take.![]()
Thank you.
Duncan.
Intercooler not part of the cooling systemmister munkey wrote:Interesting point.
I guess to start with you coulld replace the radiator, intercooler, rear heater matrix, all 16 hoses plus the metal pipes that form part of the plumbing, water pump, header tank & possibly a dozen other parts that form part of the sealed system. (I would imagine that would cost a fair bit) Then you could relax knowing that a leak is unlikely to boil your pride & joy.
Personally, I'd stick a CA in too just for extra peace of mind.
Wow what a fantastic in depth answer, like I say I'm not against the fitting of a CA I'm just looking for other preventitive answers along the way.missfixit70 wrote:Okay, you've got a mid engined vehicle anything up to 15 years old, with a radiator, 2 heater matrixes, 17 hoses, numerous metal pipes & connections & a cast iron block with an ally head. Several weak points there already, water pump & thermostats fail, mixing of incompatible jap/uk spec coolants (possibly leading to sludging, jelly like "snakes" & chemical corrosion weakening the head) fan sensors, fans, etc.dandemann8 wrote:Hi, why do so many Bongo owners fit a coolant alarmIt may give you an early warning that a problem as occurred but surly there is preventitive action prior to fitting a Coolant Alarm that we can take
Thank you.
Duncan.
Add into that the fact that under low loads, short runs etc, the rad isn't under full flow (leading to sediment settling & blockage) & the stat will rarely have to open as the cooling will be achieved by the heater matrixes & "bypass" pipework (see this thread http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=35902 ) so has a good chance of siezing/failing shut.
As discussed several times on here before & often the source of very "heated" debates, it is a very good idea to replace what you know may be a weak point, ie stat, hoses, corroded pipework, rad, waterpump & thoroughly flush it all through with a chemical flush to ensure there is no mixing of incompatible coolants, BUT most people just can't afford to do all that - I know I can't.
I've replaced all the hoses with silicon, replaced the stat & flushed it a couple of times, but I have fitted a Mason alarm to warn me if the temp is rising & a coolant high & low level alarm to warn moe of coolant loss.
Interstingly, the coolant alarm has warned quite a few people of dropping coolant levels AFTER such replacements due to very slight weeps on joints etc.
It's a risk analysis - spend up to £1000 replacing EVERYTHING possible on the coolant system & hope none of those replacements leak or fail, or do what you can & fit alarms to warn you of any potential issues (hopefully) before expensive damage is done, the choice is yours.
The main issue is the fact that the engine WILL NOT withstand overheating well like other engines will, due to its construction (cast block & ally head), so it makes sense to protect it.
One of my hoses went the day after I'd checked them, so unles you plan on lifting the seats every time you turn the key, it's a no brainer to me, the coolant alarm constantly checks the coolant level & self tests every time the ignition is turned on.
I would most definitely recommend changing the stat & a proper flush as a minimum (backflush & flow test the rad) & hoses as you can afford or as necessary & replace the rad if at all suspect.
Give it a "proper" run every so often, & when you pull over, leave the engine running until you feel the bottom hose (passenger side exiting rad) getting warm/hot, thus showing the stat is opening & doing it's job, & then feel the rad for cold spots to check it's flowing fully & doing it's job.
Just my opinions of course
