Drained coolant...fine.
Flushed with water...fine.
Backflushed rad...fine.
Removed stat and replaced seal & housing....fine.
Holts 2 stage flush..fine...but all that waiting for the engine to cool down
Spotted 2 leaks....OK, they were both at the end of the hose and I had enough length to cut an inch off as a temporary measure. New ones on order.
Replace stat with new one....fine
Top up 50/50 water antifreeze.....fine.
Start the bleeding malarkey.....fine....to start with.
No more bubbles, heater hot, all going ...fine.
But, bottom hose still cold. 45mins the same.....1hr the same...????
The stat simply will not open. (BTW it is in properly, housing nice and clean top and bottom)
So. let it cool. Check coolant levels. Pressure test-fine, no leaks.
Try the bleeding process again. This time no bubbles of course! Hot heater, cold bottom hose.
So, I took the stat out completely. Re-bled and all is well.
I tested both stats earlier with boiling water. Both opened, but the new one opened fully faster.
So now,I put both stats in a saucepan of water and heat. I use an accurate thermometer. Both open at 85C though the new one opens fully faster again.
Am I to assume the new stat is no good? 85C at the bottom of the engine =100C at the top(fitted a digital gauge to top hose).
I have now ordered a genuine Mazda stat....I hope this will solve things
The Bongo is running much better with no stat....just takes a little longer to get up to temp. I have to replace the crap hoses at the weekend, so I'll try the genuine stat and see if it actually opens before the engine boils!!!
