Lost all our coolant
Went to drop son off this afternoon and when he got out of the van he heard water................i got out and in the middle underneath there is a big metal pipe with a rubber hose on each end squirting hot water out!!!!! Its the pipe that runs near the big housing. needless to say i wish i had a coolant alarm but that said it has to be fixed before August. Ive got a mechanic just need to source the right pipe and hoses. Can i get them from bongo fury or mazda itself ???
HELP PLEASE
HELP PLEASE
Re: Lost all our coolant
thanks will give em a bell Forgot to say there was no sign of any leaks or water under the van prior to this............it just happened just like that.Am glad i was local and got to get van home where she will stay now until she is sorted.BUMMER!!!! on the bright side i am not without transport.i get use of hubbies vtec prelude for a while!! Much prefer the Bongo though
- maxheadroom
It could be Max. will just go out and have a quick look brb
- haydn callow
it's the top hose "top of rad to cylinder head (under drivers seat)"
It starts with a rubber hose.....Rad to metal pipe
then metal pipe
Then rubber hose metal pipe to cylinder head.
Put all 3 together and you have the complete top hose system
Did the tempreture gauge move towards HOT ??
then metal pipe
It is all them Hayden. Unfortunately it did rise to nearly hot. Do you think any damage is done..........it's the top hose "top of rad to cylinder head (under drivers seat)"
then metal pipe
thanks Max for thatis it one of these...
Now i know which hoses to get i am thinking maybe renew all the pipes top and bottom.......and fit a coolant alarm. It looks like the hoses are perished and would rather spend the money renewing it all as i dare say they are all the originals on the van.Looked on the cooling system diagram and i can see the top,bottom and a spaghetti of others. If you read this hayden could you advise is it 3 for the top (1 metal 2 rubber) andsame for bottom hoses please
I hope no damage was done to the head as temp guage rose to a cm before hot but i drove with heater on full wack on cold to try and keep it cool and also filled up res bottle for what it was worth. I am absolutely gutted.
- haydn callow
Yes...bottom hose is also 2 x rubber and a metal pipe...there are also another 10/15 small bore pipes
That sounds a lot of pipes or have i gone blonde and you mean the bores ???
Told you i was dim lol my god there are a lot of pipes in the system would it be best to do all of them do you think?????
- haydn callow
personally I would just check them all and replace as required......
Complete list of hoses, 17 in all on a diesel, numbers are drawing numbers, part numbers can be got from the drawings by clicking on the + symbol on the description on the left,
Main cooling system - http://www.lushprojects.com/bongopartsm ... mgno=.html
15-261 - bypass/recirc into top of thermostat
15-381 - bleed hose
15-186 - top hose/engine outlet to large metal pipe drivers side
15-183 - Large metal pipe drivers side to top of rad (inlet)
15-184 - bottom of rad/outlet passenger side to large metal pipe passy side
15-185 - passy side large metal pipe to bottom of thermostat
15-227 - top of rad to header/expansion tank
15-188 - expansion/header tank to heater return pipe
Most of front & rear heater system - http://www.lushprojects.com/bongopartsm ... mgno=.html
61-211 - drivers side heater pipe to front heater matrix
61-212 - front heater matrix to heater return pipe
61-214 - heater return pipe to thermostat
61-213 - outlet over starter on engine, drivers side to heater pipe
61-211A - drivers side heater supply pipe to rear heater matrix
Rear heater return - http://www.lushprojects.com/bongopartsm ... mgno=.html
61-212C - rear heater matrix to return pipe behind engine
Another rear heater return - http://www.lushprojects.com/bongopartsm ... 1of02.html
61-213A - rear heater return pipe connector behind turbo under passy seat
Two turbo cooling hoses - http://www.lushprojects.com/bongopartsm ... mgno=.html
13-539A &
13-546 - turbo suppply & return hoses
15-381 - bleed hose
13-539A &
from my experience if your hoses start to go,this indicates that the stat is not doing its job properly,sorry but just something else to look at.
