Damp smell after using air-con
Truant
Hi All,
I have a bit of a weird problem. Am currently on holiday in the bongo and it has been HOT (i.e. 40 degrees etc). Consequently have been using the air-con which has been great. The only problem is that the following day(and for a few days afterward) there is a really strong damp smell coming from the air vents. I grew up in a hot climate and have had air-con in cars before without this problem. Does anyone know what might be causing it in my Bongo?
Many thanks!
Many thanks!
Re: Damp smell after using air-con
Lack of use? Aircon will pong if not used regularly
Truant
I do normally switch it on at least once a month however, admittedly, it is not usually for more than 5 minutes. Over the past fortnight it has had a bit of a flogging! Is there anything I can clean etc to try and prevent it happening again?
Does it smell like burning celery?
They flew, I took up naturism
Good chance the evap matrix is clogged with crap that's full of bacteria etc, good idea to remove the ducting under the bonet to get to it to clean it out.
Truant
Sorry but I am Not really sure what burnt celery smells like!!
Will check out under the bonnet for this filter. Sorry for my ignorance but could you be a bit more specific on the location I should be looking?
Many thanks!
Many thanks!
You could try something like this,it might help.
http://cgi.ebay.co.uk/CAR-AIRCON-CLEANE ... 4ceaac5954
There isn't a filter , evap matrix is in 6110 here - http://www.lushprojects.com/bongopartsm ... mgno=.htmlTruant wrote:Sorry but I am Not really sure what burnt celery smells like!!
Many thanks!
This factsheet explains how to get to it - http://www.igmaynard.co.uk/bongo/member ... repair.pdf
Be careful with the fins on the matrix they're fairly fragile.
Truant
Sorry about the delay in saying thanks however I haven't had internet access. Will follow up these ideas and hopefully remove the pong! Thankyou guys for your assistance.
You've not been the only one with the same issues recently - http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=42416
