Fuel guage not working
Bongowner
Post by Bongowner » Wed Mar 02, 2011 6:57 pm
New to Bongos - just got one sent over from Japan. Have changed the speedo dial face and reassembled the unit without the perspex facia (for calibration purposes) but now the fuel gauge isn't working. :( Even before I took the unit out it was painfully slow taking ages for the needle to move from rest position but now it just doesn't seem to want to move at all.
Is slow normal?
I checked all the contacts are clean and secure on the printed circuit at the rear of the unit and the connectors are in securely but to no avail. Any help or advice would be appreciated but please bear in mind that I am not at all mechanically or electrically minded.
Many thanks
Bongowner
westonwarrior
Re: Fuel Gauge - misbehaving
Post by westonwarrior » Wed Mar 02, 2011 7:06 pm
Hi bongo owner Yes its normal for the guage to be slow but to not work at all may mean a connection error
Re: Fuel guage not working
Post by francophile1947 » Wed Mar 02, 2011 7:10 pm
It is very slow to rise. If you fill up and it doesn't read full (after several minutes), you may have a bad earth - loads of threads about that 8)
jaylee
Post by jaylee » Wed Mar 02, 2011 7:49 pm
Bongowner wrote:New to Bongos - just got one sent over from Japan. Have changed the speedo dial face and reassembled the unit without the perspex facia (for calibration purposes) but now the fuel gauge isn't working. :( Even before I took the unit out it was painfully slow taking ages for the needle to move from rest position but now it just doesn't seem to want to move at all.
Is slow normal?
Many thanks
Bongowner
Slow is normal.. The fuel gauge also holds position when the ignition is off.
