Ticking sound from 2L engine
Wakeybongo
Post by Wakeybongo » Sun May 15, 2011 7:51 pm
2L petrol (new shape) developed a bit of a ticking when engine running.
Anyone any ideas?
Cheers.
Ian.
Re: Ticking sound
Post by missfixit70 » Sun May 15, 2011 7:53 pm
Check the reset button on the tripmeter has been pushed in properly, wouldn't be the first time :wink:
Re: Ticking sound
Post by Northern Bongolow » Sun May 15, 2011 9:28 pm
missfixit70 wrote:Check the reset button on the tripmeter has been pushed in properly, wouldn't be the first time :wink:
done that one myself :oops: :oops: #-o .
check the fan belts,you may have a fraying belt.
or some petrols (not usually bongos) tick from the exhaust manifold when the gasket is put- putting,leaking. check around this with soapy water,and look for bubbles.
or the diesels tick on the fuel filter because of the internal valve/flap if its a gen filter,this may apply to petrols to.worth a check though.
Re: Ticking sound from 2L engine
Post by haydn callow » Mon May 16, 2011 8:08 am
Sticking valve lifter ??
Post by teenmal » Mon May 16, 2011 12:02 pm
haydn callow wrote:Sticking valve lifter ??
Ditto,I would go with the Valve Train.
Cheers..
crazy uncle gray g
Post by crazy uncle gray g » Mon May 16, 2011 1:11 pm
:-k It could be something as simple as a loose plug or lead for that fact 8)
cheers! party on dudes.
Post by haydn callow » Mon May 16, 2011 1:40 pm
crazy uncle gray g wrote::-k It could be something as simple as a loose plug or lead for that fact 8)
Yep !!! a plug lead shorting to earth would "tick" I would also expect you to notice a "misfire" if that was the case......But well worth checking the leads......have a look in the dark and you may see a "spark"
mikexgough
Post by mikexgough » Mon May 16, 2011 6:23 pm
could be many things...... can't really give an idea without hearing it......
Wakeybongo
Post by Wakeybongo » Thu May 19, 2011 9:55 pm
Overdue oil and filter change has sorted it!! :oops:
dunslair
Post by dunslair » Fri May 20, 2011 8:11 am
Wakeybongo wrote:Overdue oil and filter change has sorted it!! :oops:
Less of a tick and more of a tut tut then :wink: nice to see its sorted =D> :D
