Help please - wheel noise
psquiddy
Post by psquiddy » Thu Jun 02, 2011 6:58 pm
It sounds like I have a flat tyre until I get to about 30mph, then seems ok - any suggestions? I have jacked up the front wheels and all seems solid and connected, no obvious problems.
Over 300 free things to do in London
http://www.toplondondaysout.co.uk
jaylee
Re: Help please - wheel noise
Post by jaylee » Thu Jun 02, 2011 7:05 pm
Had a similar problem a couple of years ago... dub,dub,dub,dub,dubdubdubdubdubdubdub.... Speed related!
For me it turned out my font off side tyre was like an egg! :shock: Pot holes...
MAZABON
Post by MAZABON » Fri Jun 03, 2011 9:29 am
try swaping the front wheels, one side to the other see if the sound moves with it, then you will know if its the wheel/tyre or not
daveblueozzie
Post by daveblueozzie » Fri Jun 03, 2011 10:40 am
Make sure your nuts are tight :? :shock: and if you have alloy wheels that they are the correct nuts for the wheel, i had my wheels balanced 5 times before the fault of the wrong nuts being found. #-o
Make sure you have spigot rings if you have alloy wheels,(plastic ring that fits on the hub)
Lost without my Bongo.
Post by Muzorewa » Fri Jun 03, 2011 10:48 am
Could just be unevenly worn tyres especially if it's a 4WD with a viscous coupling that is past its best.
Ours is fine on new tyres but when they're well worn on the inside edge (still loads left in the centre and outside edge) I get odd noises at about 20mph. Every time I put new tyres on it's like a different vehicle.
Oh, and our VC is WELL past its best :lol:
progroup
Post by progroup » Fri Jun 03, 2011 2:09 pm
How many kilometers on the vehicle :?:
Post by Muzorewa » Fri Jun 03, 2011 2:10 pm
Ours?
progroup
Post by progroup » Fri Jun 03, 2011 3:07 pm
Muzorewa wrote:Ours?
No I'm sorry, I meant 'psquiddy' #-o
psquiddy
Post by psquiddy » Fri Jun 03, 2011 10:29 pm
Its done about 105000 miles but the problem has come on in the last week (it may have been there before but it is now very noticeable) - we have been in the outer hebrides this week and some of the potholes are awesome so it may have brought matters to a head.
We are now in Ullapool, which seems to be as far away from a tyre shop as is possible to get - it drives ok (ish) but I am thinking I should divert to Inverness (70 miles each way) to get it checked out.
psquiddy
Post by psquiddy » Sat Jun 04, 2011 5:00 pm
Got it checked out at Ullapool garage, tucked away in Ullapool on Mill Street - they put it straight on the ramps and spent 20 minutes looking it over - nothing to report apart from a bit of normal wear and tear, so I can stop worrying now.
I would recommend these chaps if you are in the area.
