Started my bongo this afternoon. Both the charge light and the sediment light failed to extinguish.
Drove about 40 miles home without a problem. Read some old threads which suggested my alternator is the likely problem.
Is it worth getting the alternator and battery checked or should I just bite the bullet and get a new alternator?
Charge Light and Sediment Light on together.
Re: Charge Light and Sediment Light on together.
Check the battery voltage with the engine off, should be 12.5v ish.
Check the output voltage from the alternator with the engine runnning, should be between @13.8v & 14.6v. Could be the battery is goosed too which may be cause or effect of the alternator.
May be worth charging up the battery for 48 hrs if it's low & seeing if holds charge.
