so, the story goes like this...
had some work to the exhaust manifold done as we had the squeaks (like a fanbelt). it was the stud at the rear of the engine that had gone. had this work done by a non-bongo specialist garage. after about ten minuted driving around after picking it up 5 litres of coolant dropped out of the system (aagghh!). i am quite sure it didn't overheat, thank goodness the wife noticed a "grinding" noise and pulled over (though this noise may be a red herring) and noticed the coolant leak. the AA filled it up with water and we drove home (1mile) and back to the garage in the morning (1/2mile). The AA tested for CO2 in the coolant system and found none (CO2=headgasket or cylynderhead damage). could have been MUCH worse.
... 2nd visit to the garage, they took care to properly replace the coolant at their expence (how kind?!) and i think its okay. However, we now have a new problem. a slightly intermittent but REALLY serious loss of power at under 2000rpm and then, when it gets going, quite a lot of whiteish smoke, which smells like unburnt fuel. once over 3000rpm and travelling at 30mph it has some spriteleynessback, but at low speeds and revs, COMPLETELY gutless, so much so it is almost undrivable.
our mechanic (I am looking for a replacement) suggested that it could be a build up of inlet manifold sludge.
Does this sound right?
Could these symptoms be caused by be anything else?
I think I have a few options;
1/ italian tune up i.e. bang down the motorway at 80+ for an hour or two, and hope it clears it
2/ take off the inlet manifiold and clean it out (or replace, they are only 20 odd quid)
3/ disable Exhaust Gas Recirculation and stop the sludge getting in (see http://www.igmaynard.co.uk/bongo/Forum/ ... f=3&t=6479)
is there any other things i might check?
Any advice greatfully recieved
Cheers,
Tom
