after changing a hose and fully bled the system using seesaw method with coolant on the max level in tank,the coolant rises to the top,
its fine when super cold and doing small trips.
the engine didnt over heat at any stage got to 100 0c max,i have a tam2 haydon led display high AND low coolant alarm.with probe bolted to the rear of block
no white in engine oil,starts fine
could this be the water pump,or thermostat??
not loosing any coolant over night..
Thanks guys just dont know what route to go down next
