? very hot Handbrake and console ??
I have noticed today that the handbrake seems hot at its base, also the cabin seems warmer around my legs??
I have checked oil, water and the Fan comes on when the engine is warm
Is it that i am going mad or is there a sensible answer to this ??
Not very mechanically minded??
Wild Women from WONGO there are none in my BONGO !!
I'm sure I've read recently that a hot handbrake is a symptom of the scavenger fan not working. If you scroll down on this page you will see a link called 'Scavenger fan'. This explains how you can test if its working.
1995 N reg 2WD AFT in green/grey
www.whiteroseancestry.co.uk
If the console is getting hot whilst driving the fan may not be working.
If You have had the Bongo stood for a while after a journey the console and handbrake will get a bit warm as the heat rises from the engine it has to go somewhere and an escape route is around the handbrake.
An easy way to see if the fan is working is to listen,after a journey turn off the engine thenstart up again You should hear the fan running before You start it back up.
Hope this helps
Dabs
Hope this helps
Dabs
Dabongo,
I have just taken Bongo for a drive and the scavenging fan is working, I think it must be as you stated that the heat is rising whilst idle to warm wth handbrake base.
I havnt noticed this before !!
Must be the change in the weather , making the cabin warmer!! combine this with me working nights for the past two weeks, making my own internal temperature gauge not function as norm.
Happy Camper
Kentish Paul
How long have you had a Bongo? I note you joined this forum in Feb this year. I do NOt want to distract you from checking all the obvious especially the scavenging fan as serious problems may result. However, I remember a similar experience the first summer. The latent heat generated by sitting over a meaty engine became suddenly very apparent.
Bongo National Party - The law-abiding should have rights too!
- Peg leg Pete
My handbrake got hot, I cleaned the contacts for the sensor for the scavenger fan, stayed cool since
Pete- brorabongo
Matt&JoyBongling
- Tribal Elder
We had a senile moment the other day - our console was getting very hot, particularly towards the back. It was also getting hot in our cabin even with our windows open and a nice breeze. I played with the controls and found that the "rear" button had been turned on - we turned it off and the heat stopped immediately. It transpired that our Captain Kirk son had been playing with the heat controls and set the rear temp for max while playing in the back and then turned the rear heat control on at the climate control panel.
Underground, Overground, Bongoling Free, the Bonglers of Bedford, common are we ...
