Winter Pack Valve Stuck On - Help!
Hi all,
I stupidly 'tested' the winter pack valve - now it's stuck on! Running like a bag of spanners and averaging 16mpg
I need to know how to turn it off / disable it - but I'm clueless. The switch now doesn't work.
Any advice would be very gratefully recieved.
Re: Winter Pack Valve Stuck On - Help!
Do a search for EGR blanking plate Allans Vehicle Services do them easy to fit and no more Gunk in Inlet Manifold
hope this helps
corrour
hope this helps
corrour
I would walk 500 miles.
99 Tinted tintop
Supplied and looked after by Bongospares
99 Tinted tintop
Egr is NOT the cold start/winter pack valve - completely different gubbinscorrour wrote:Do a search for EGR blanking plate Allens Vehicle Specialists do them easy to fit and no more Gunk in Inlet Manifold
hope this helps
corrour
Egr redirects some of the exhuast gas from the turbo back into the inlet manifold, operates automatically, fitted to all diesel bongos.
Winter pack valve shuts a valve in the exhaust, helping the engine warm up quicker in cold climates, operated by a switch by your right knee on the dash with a picture of an engine on, only fitted to Bongos from the North of Japan subjected to extreme cold, in cojunction with twin starting batteries.
EGR is nothing to do with the winter pack as such, other than they are both associated with the exhaust.
I think the winter pack valve is in the front part of the exhaust right after the manifold joint - see if there is any sort of operating arm you can get a grip on and free it off.
Not sure if this helps at all http://www.lushprojects.com/bongopartsm ... mgno=.html - looks like a bit of the spindle should be accesible, may be able to get a spanner/mole grip/pipe wrench on it? Maybe while someone operates the switch - just watch it doesn't rotate the wrong way & crush your fingers
Once it's opened Disconnect the switch
Great minds Scanner
i am sorry to give you wrong info but i had similar problem and i cured mine
I STAND CORRECTED BY MY BETTERS AND ELDERS
99 Tinted tintop
99 Tinted tintop
Well done missfixxit70 thats exactly what i was looking to remove on the other post you replied to this is very handy thanks.
http://www.lushprojects.com/bongopartsm ... mgno=.html might help too
Sorry about highjackin' this post but,
once again missfixxit70 thanks ive been looking for something like this all day.
bet you've got a sonic screwdriver just like Dr Who
Do you do time travel aswell
SERIOUSLY THO THANKS FOR TAKIN THE TIME.
- daveblueozzie
WHO is that mystery girl they call Missfixit ?
She can fix a spaceship ive been told.
DR WHO learned all his stuff from Kirsty i bet.
The bongo is no mystery to Missfixit.
Just the girl behind the spanner and a hammer is the mystery.
Lost without my Bongo.
Who? Taught him everything he knows - only he doesn't know it yet cos it'll be 20 years in his futureBongo.Baz.tard wrote: Sorry about highjackin' this post but,
It's all in http://www.lushprojects.com, just got to dig around a bit.
Thank you!
