heater plug relay??
- dandywarhol
Re: heater plug relay??
100A?
I am stuck now, the local parts shop only does fuses up to 35amp.. any other ideas?
- haydn callow
50 amp !!...but get a replacement fuseable link asap
Hi mattnicks,
If you disconnect the cable from the rail,this will eliminate the rail and the heaters.
Cheers..
Cheers..
I have now used a 2inch piece of the old fuseable wire as the 30amp ones wee not enough, and its done the trick starts and no probs and no shorting out anywhere.
Do you guys know where I can get some more of that fuseable wire from?
Thanks once again for all the pointers its been real help
Cheers Matt
Cheers Matt
Hi,try your motor factors etc for a WAFER FUSE..mattnicks wrote:I have now used a 2inch piece of the old fuseable wire as the 30amp ones wee not enough, and its done the trick starts and no probs and no shorting out anywhere.
Cheers Matt
Cheers..
If you google it you will see what I mean..
