alternator faulty???
FREDA MIND
Post by FREDA MIND » Fri Jun 04, 2010 7:39 pm
hi bongo dudes, my charge light lit up on the way home tonight :( ive just checked the voltage on my battery with engine running and idle and there is a slight drop when running from 12.3v to 12. v,,, :(
ive checked the wiring and connections to the alternator- all apperars fine.
are there any other checks i can do to the alternator before replacing it- continuity of the windings? if so how???
ive been quoted £330 pound for a new unit from my local motor factors!!!! :shock: :shock:
however i found this new unit on ebay with a one year warrenty and no exchange.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
looks like a good deal to me what do you guys think of the above?
just want to be sure its deff alternator fault before i spend my hard earned cash.
any help much appreciated
ricky 8) :D
have yourself a midlife chrisis,,,,go buy a bongo!
You've Been Bongod
Re: alternator faulty???
Post by You've Been Bongod » Fri Jun 04, 2010 7:41 pm
before you do buy a new one go to kwickfit and they will do a FREE test
rita
Post by rita » Fri Jun 04, 2010 7:43 pm
You've Been Bongod wrote:before you do buy a new one go to kwickfit and they will do a FREE test
Ditto... and are the belts ok..
FREDA MIND
Post by FREDA MIND » Fri Jun 04, 2010 7:45 pm
cheers rita, belts are fine :)
thanks for your help
321Away
Post by 321Away » Sat Jun 05, 2010 10:42 am
fleabay!!! new from about £120 and easy to fit
apole
Post by apole » Sun Jun 06, 2010 5:48 pm
One thing worth checking is there's a 12v feed to the alternator voltage regulator when the ignition is on, check the voltage regulator is getting this first, if it doesn't get the 12v feed it doesn't put any charge out. Worth checking. Not sure which one that would be on a bongo mind, maybe someone else can advise.
Andy
FREDA MIND
Post by FREDA MIND » Mon Jun 07, 2010 10:01 am
thanks andy,
this is well worth checking
ricky :D
Tripewriter
Post by Tripewriter » Mon Jun 07, 2010 6:32 pm
Voltage from alternator should be above 13v or the battery wont charge. However if a cell has gone down in the battery it may well give a false reading from the alternator. Kwik fit test best idea.
FREDA MIND
Post by FREDA MIND » Wed Jun 09, 2010 10:38 am
replaced alternator this morning and it has fixed everything. charge light and sediment light both go out on start up now,
\:D/ :D
thanks as always for all your kind help,,,, this is a great site that is really so helpfull!!
cool beans bongo dudes
ricky 8) 8) :D :D
