being a new bongo owner and a regular forum reader i am bit concerned about all the over heating problems and cracked heads can anyone tell me why this seems to be a problem, and is there any way to detect this or any special servicing methods used to reduce any problems
many thanks
neil
how to prevent over heating
A Bongos is not just for christmas
- Peg leg Pete
Please do not worry, many bongos run without an hitch for years without any problems, if you keep on top of servicing Overheating can occur if the coolant system is not maintained as per the handbook. Coolant should be changed every 2 years, and the system must be bled via the bleed pipe under the passenger seat. The radiator should, in my opinion be flushed at the coolant change, and any leaks however minor should be repaired.
Pete
