Help!! Fuel filter priming/white smoke
Need help from someone who has done this job...
I changed the fuel filter lastnight, following the instructions in my newly aquired manual, as far as I could..
The manual shows a primign pump on top of the filter housing.... Mine does not have such a device... it is smooth....
Does it self prime?? and if so why will it not rev or go over 25mph and spews out white smoke when I floor it. Injectors blocked??
the gasket is ok (oil and water both clean and full), and it idles fine.
Aaarrrrgh
Andy
Aaarrrrgh
Andy
Fuel Filter Change.
I think diesel Bongos are self priming and if you run the engine gently for a while it will clear itself of any air in the fuel system and will run OK again.
Some Bongos have a primer and some don't as with mine. It is self priming ie. keep turning starter (in 6 sec bursts) until it fires. You may need to give the throttle some wellie to clear out the air and until it runs smoothly. I've done this twice with mine now and the self-priming worked fine. If after a short while your's has not cleared, suspect an air leak in the system. Maybe the gasket has not seated properly?
- dandywarhol
- dreamwarrioruk
lift drivers seat.
where the throttle assembly is there is the injection block. Near to the engine on the front far corner there is a solid pipe leading to a banjo top from the fuel filter.
Remove the banjo via the bolt on top. belo there is a spring with a small gauze filter, remove clean and replace. Dont leave it out as this is the last defence from serious damage to the injector pump.
Im sorry if its a bit vague im working from memory and my cameras in too many bits to take a photo.
If you struggle i will have a look and try to discribe it better.
- dreamwarrioruk
