Hi all
How critical are the level's on the gearbox dipstick.? I've just had mine in for a full service and on re checking (when engine was cold) found that the fluid was about an inch over full!
Auto Transmission
- Junior Bongonaut
Auto Transmission
Don't come a knockin if me Bongo's a rockin!!
http://www.familyfootsteps.co.uk
- Junior Bongonaut
Thanks for that Colin Will run and check tonight.
What equipment would I need to suck oil out if still over full ?
Getting oil of the auto box.
Realised that my gearbox had way too much oil after checking it properly when I got the Bongo.
Shopping at a Farmers store (I live in the country) I found a large syringe with a very small diameter long tube used for getting fluid out of sheep (have you had yer tea!). It had a spare tube which I taped to the original making it over 2 ft long. I secured the farmost tube with wire incase it fell into the gearbox and pushed the whole lot down the dip stick/filler tube. Managed to suck up a litre of oil very easily without pushing crud down the tube.
The whole lot cost less than ?2.
Bonz
Bonz
- Junior Bongonaut
Cheers Bonz
Managed to find exactly the same thing from our local farmers store.....easy peasy, sucked out over a litre and half of oil. Re checked levels a couple of times, no problem!
Thanks again, much appreciated
