heater problem after coolant change
Hi folks,bit of advice needed please.just changed a couple of hoses and the stat,went through bleeding process bottom hose hot fans kicking in etc.when switching on heater seems to blow cold unless turned to highest setting .it's a 2-5. diesel with the digital heater controls.Cheers Tay.
i chose not to choose life ....i chose a bongo instead
Re: heater problem after coolant change
Try bleeding it again tomorrow
Mine burped some more air out the next day
Are all the heater connector rods conected in the front foot wells to operate heater
Will try again tomorrow and check connections,thanks for the reply
dont they all with the digital controls act weird, doesnt it depend on if its in the sun, or if the cabin is up to temp etc,etc.???
lean under the front heater fan under the bonet and check the heater pipes in and out, if they are very hot its down to the controllers of the heater.
Cheers ady I was thinking it may be something else as it was like it before I did coolant change,I thought it was maybe the stat but I've replaced that so I can rule that out.would it be the actual control panel inside the van I need to replace.
Probaly the fan resistor thing that controlls fan speed
Or fan full of water
- g8dhe
If its the digital version and the fans ONLY blow when set to Max. then normally its the transistor blown, at the Max. setting a relay bypasses the transistor. They are replaceable see http://www.dalbani.co.uk/2sd1525-toshib ... 5-buy.html
The fans blow ok it's the temperature I'm getting a problem with when I set it to max 32 degrees they are hot turn down 1 degree and they go cold.
if your bleeding it again take the extra time and back flush the heater matrix with a hose first
g8dhe wrote:If its the digital version and the fans ONLY blow when set to Max. then normally its the transistor blown, at the Max. setting a relay bypasses the transistor. ...
Don't you just love improvements to things which worked fine in the earlier version? I often yearn for a newer Bongo but apart from the smarter looking front I wonder if I would be buying into a new set of problems.
Frank
They flew, I took up naturism
They are a Labour of love,but with the help of every one on here you always end up with a good outcome
has anyone mentioned the little fan and sensor next to the passy side glove box, the little grill thing, doesnt that need a hoover out every now and again.
im with frank on this one, i was at the do i replace stage or weld my old one, im glad to say i welded it. you can keep your improvements, it was good the first time.
thats the little chappie thanks geoff. doesnt this do the cabin sensing, so if the cabin is hotter the preselected temp the unit wont give heat, it will actually try to cool it to the selected temp.
- g8dhe
Yup thats right, it will feed cool air in.
