That's exactly what happened to mine, the speaker had new wires strapped to the top of the existing flexy bit, the wires had been repaired by someone else followed by near total failure of everything else.g8dhe wrote: ↑Thu Mar 17, 2016 8:10 pm Once one wire has broken, then others in the loom are likely to follow, they are all being stressed at the same time! So its not uncommon to find that several of the wires are already broken but being held in place by the insulation alone, these will eventually give and go intermittent followed by breaking entirely.
While the loom could have been fixed, a new one was easier, at least it has in-built speaker leads!
Did I forget to mention the passenger window failing to operate from the driver's side? The driver's window was the only thing remaining operative in the end.
