tappets
ribbleman
tappets
Post by ribbleman » Sun May 01, 2016 9:57 pm
At what mileage should tappets be reset
thanx steve
philpdr
Re: tappets
Post by philpdr » Sun May 01, 2016 10:33 pm
Had mine done in October at 80.000 miles,but only because it got noisy.
rita
Re: tappets
Post by rita » Mon May 02, 2016 9:14 am
The Valve clearance should be checked at every major service.
ribbleman
Re: tappets
Post by ribbleman » Mon May 02, 2016 2:51 pm
Thanx, About due then 90,00 miles!.
Re: tappets
Post by mikeonb4c » Mon May 02, 2016 3:59 pm
rita wrote:The Valve clearance should be checked at every major service.
It's a good point Rita. At what intervals should a Bongo have a major service. Doesn't get discussed a lot!
Have to fess up and say my tappets got adjusted at 125k miles when i had a new head fitted :oops:
Re: tappets
Post by Northern Bongolow » Mon May 02, 2016 6:43 pm
maybe a good time to do the rocker cover gasket at the same time too.
Wilbaforce1
Re: tappets
Post by Wilbaforce1 » Wed May 04, 2016 10:01 pm
Hi, would my 99 V6 have hydraulic Tappets as I have been told they have. They have become quite noisey on start up but stops when warm. Any advice please would be appreciated.
Simon Jones
Re: tappets
Post by Simon Jones » Wed May 04, 2016 11:53 pm
Welcome to the forum :). Yes, your V6 has hydraulic tappets. Might we worth an oil and filter change but don't use an engine flush as I found that made them slightly noisier.
Wilbaforce1
Re: tappets
Post by Wilbaforce1 » Thu May 05, 2016 6:49 am
Many thx, I will try that.
Wilbaforce1
Re: tappets
Post by Wilbaforce1 » Thu May 05, 2016 8:20 pm
New oil and filter done and sounds a lot better. Still here it a bit so should I be concerned at all. Has anyone had success taking the sump off and checking the oil pick ups. This was also recommended
teenmal
Re: tappets
Post by teenmal » Fri May 06, 2016 2:18 pm
Wilbaforce1 , instead of removing the sump etc , personally I would simply check the Oil Pressure, if its ok the HLA are probably getting past their sell by date.
Wilbaforce1
Re: tappets
Post by Wilbaforce1 » Fri May 06, 2016 10:08 pm
Thank you. My Bongo has only done 66000 miles though.
Wilbaforce1
Re: tappets
Post by Wilbaforce1 » Fri May 06, 2016 10:09 pm
I will check the oil pressure though, cheers
teenmal
Re: tappets
Post by teenmal » Sat May 07, 2016 10:18 am
If the oil pressure is in range it is sometimes best to leave and let it develop, but if you are feeling "Brave" you could remove the HLAs strip, check for wear , clean prime and refit. A word of Warning if this procedure is not carried out properly you can have severe difficulty starting the engine .You may actually need to fit a new set in order to restart the engine..
Wilbaforce1
Re: tappets
Post by Wilbaforce1 » Sun May 08, 2016 5:42 pm
thank you for the advice, much appreciated. i will keep using her but keep an eye on it, it stops completely now when up
to temp. regards
