Gear trouble - NO flashing hold light
Driver+Passengers
Post by Driver+Passengers » Fri Jul 22, 2016 9:18 pm
Hi, folks!
Trouble started yesterday - high revs before changing up, or have to back off almost to the point of decelerating - doesn't go into top. No flashing hold light, but can confirm the bulb works.
I'm massively strapped for time so while I'd usually trawl the forum and get in about understanding it, any chance of a leg up??
'96 4WD AT
ATF is a few years old but clean and level appears good.
Matt.
Image Image
Re: Gear trouble - NO flashing hold light
Post by Northern Bongolow » Fri Jul 22, 2016 9:45 pm
check the usual matt. air filter, banjo and fuel filter, then check the turbo pipe to the intercooler and back to the inlet manifold.
thin black pipe from air inlet manifold bend at driverside front to the top of the pump, this gets full of crud.
switch /wire /plug for gearbox on side of gearbox check connection.
Post by Northern Bongolow » Sat Jul 23, 2016 1:15 pm
sticking brake/s.
roosmith
Post by roosmith » Sat Jul 23, 2016 2:05 pm
I had those exact symptoms and a change of ATF and clean filter sorted it out but I appreciate you say yours is done.
Post by mikeonb4c » Sat Jul 23, 2016 3:04 pm
Throttle position sensor playing up?
I Bongo, therefore I am...
Bongoing, BonGoing, BonGone
Driver+Passengers
Post by Driver+Passengers » Sat Jul 23, 2016 7:23 pm
Northern Bongolow wrote:sticking brake/s.
Doesn't feel loaded, just replaced front pads last night, will check rear.
Edit: lower bolt to carrier is a bit sticky - boot perished, uneven wear on one of those offside pads.
Last edited by Driver+Passengers on Sat Jul 23, 2016 7:29 pm, edited 1 time in total.
Image Image
Driver+Passengers
roosmith wrote:I had those exact symptoms and a change of ATF and clean filter sorted it out but I appreciate you say yours is done.
Can't rule it out, though.
Image Image
Driver+Passengers
Post by Driver+Passengers » Sat Jul 23, 2016 7:24 pm
mikeonb4c wrote:Throttle position sensor playing up?
Will get the multimeter on it shortly.
Image Image
Driver+Passengers
Post by Driver+Passengers » Sat Jul 23, 2016 7:27 pm
Northern Bongolow wrote:check the usual matt. air filter, banjo and fuel filter, then check the turbo pipe to the intercooler and back to the inlet manifold.
Air filter looks fine. Thin black pipe to pump is fine. Only thing a visual check threw up is tremendously oily/cruddy hose clamps on the manifold side of the intercooler - just 3 or 4 inches worth - everything else around that area looks fine though. Haven't removed to inspect inside yet. EGR is blanked, but it is losing oil over time, so maybe turbo seals going?
Image Image
Driver+Passengers
Post by Driver+Passengers » Sat Jul 23, 2016 9:10 pm
Connected TAT to GND - getting code 16 from hold light (and FAT pin). Could be 10 and 06 - but think it's 16.
Removed battery(s), held brake pedal. 10s long enough?
Haven't driven yet - getting same code immediately. 16 not listed?
Edit: having read http://igmaynard.co.uk/bongo/forum/view ... =3&t=71627, code 06 would indicate speed sensor, and fit with symptoms. If so, what is 10? If not, what is 16??
Image Image
Post by Northern Bongolow » Sat Jul 23, 2016 9:34 pm
the speed sensor on the bottom front of the engine sometimes gets oil behind it, remove the 10mm nut then pull gently as there is an O ring seal, wipe out the socket it fits into then wipe the sensor face and refit.
Post by Northern Bongolow » Sat Jul 23, 2016 9:41 pm
http://igmaynard.co.uk/bongo/forum/view ... or#p579929.
theres also the gearbox speed sensor, search gearbox sensor by simon jones, theres loads of info and pics, this could link back to the tps etc.
Driver+Passengers
Post by Driver+Passengers » Sat Jul 23, 2016 9:44 pm
I brought a wire out from the ECU for logging the TPS, so these measurements are effectively taken at the ECU.
Closed - 0.8V
Open - 3.9V
By the book, it's 1.3V and 4.2V respectively.
Doesn't smell like the cause to me...
Edit: though http://igmaynard.co.uk/bongo/forum/view ... =3&t=69418 suggests that TPS faults can be temperature related. I'll put a simple voltmeter on the end of my TPS wire and monitor when driven.
Last edited by Driver+Passengers on Sat Jul 23, 2016 9:58 pm, edited 1 time in total.
Image Image
Driver+Passengers
Post by Driver+Passengers » Sat Jul 23, 2016 9:56 pm
Northern Bongolow wrote:http://igmaynard.co.uk/bongo/forum/view ... or#p579929.
Does the fact the rev counter work discount engine speed sensor, or is that taken from elsewhere?
Image Image
Post by Northern Bongolow » Sat Jul 23, 2016 10:43 pm
dont know, but it only takes 2 mins to strip and clean anyway, so - - - - -
