Someone has recommended that I attach 8mm closed cell foam and a layer of 2mm noise suppression stuff (forget the name at the mo) under the front seats, in the engine access areas to help with noise.
Has anyone done this style of thing? Did it help reduce engine noise inside the cab?
What type of glue did you use?
Any experience welcome.
Olly
Installing noise suppression in the engine access panels
Re: Installing noise suppression in the engine access panels
I have some dodo mat hex attached to mine, it’s self self adhesive as are most vehicle foams and sound insulation. I haven’t thought about attaching some closed cell foam but I’ve got loads of the kiravans silver stuff left over (7mm I think) so could do (if you’re anywhere near Sheffield you’re welcome to some). It’s not as much of a problem in my v6 as it was in old diesel.
- ever after.
I thought about doing something similar but was worried incase the sound deadening material couldn't deal with the heat
Any photos when you're next under the seats, would be appreciated. Interested to see how to goes on.cwilliams255 wrote: ↑Sun Aug 02, 2020 11:07 pm I have some dodo mat hex attached to mine, it’s self self adhesive as are most vehicle foams and sound insulation. I haven’t thought about attaching some closed cell foam but I’ve got loads of the kiravans silver stuff left over (7mm I think) so could do (if you’re anywhere near Sheffield you’re welcome to some). It’s not as much of a problem in my v6 as it was in old diesel.
I think you can get heat proof ones from the better suppliers. It's not cheap, but might be worth it.ever after. wrote: ↑Sun Aug 02, 2020 11:29 pm I thought about doing something similar but was worried incase the sound deadening material couldn't deal with the heat
- Bongonaut
I have put 10mm Dodo in my doors and under the seats, while I was fitting the cloth MX5 seats in the Winniebongo, I only have a couple of pictures which I have put on Instagram if that helps
https://www.instagram.com/p/CDcDwSNJVff ... 2fp09l97hs
- Apprentice Bongonaut
I used Noico 80mil on mine. Did a pretty good job.
