Fuel pump seal
helen&tony
Fuel pump seal
Post by helen&tony » Sun Sep 20, 2020 8:53 am
I have / had a starting issue, changed another couple of vacuum lines, even though they appeared undamaged, and the starting was fine???...BUT, there's a leak on the fuel pump (diesel) side plate that the throttle arm fits onto...just above the side-plate (domed) which retains the piston assembly. Now here's the thing, I have the official Bosch / Zexel assembly diagram, and it doesn't show a seal or removeable plate, but it clearly has one, as it's leaking around the allen screw, and bottom of the plate....Does anyone have any info...?
plonkatronix
Re: Fuel pump seal
Post by plonkatronix » Sun Sep 20, 2020 9:34 am
Options, either send the pump off for a rebuild to a specialist or buy the two green seals and fit them yourself, seems to be a common issue with these
Protect Yourself, IP BLACKLIST freely available@ http://plonkatronix.com
helen&tony
Re: Fuel pump seal
Post by helen&tony » Sun Sep 20, 2020 10:03 am
I've done the seals before, but this appears to come from above the domed plate????...It's conceivable that it could be spraying upwards???...but in the new year, I'll probably get a new pump....and then there's the issue of finding someone to fit it!.....LOL....I know how, but I don't have the physical strength these days (old injuries)...LOL....I might try the side seal on spec, but I'm itching to find out what the seal above is, and why it's not listed on the parts sheet???....It could even be a gasket??
