Dodgey
Post
by Dodgey » Tue Dec 02, 2014 11:34 am
You need to trim the upper outer edges of the step and then it will fit back on. Then you put the same ply under the bottom of the step so it has something to rest on and fix to.
I did a full step by step on here but it got deleted somehow ( a full conversion from start to finish)
Spencer54 wrote:OK i'm all done - with the exception of the step, that seems to be the stumbling block.
Now its so much higher it doesn't want to go back on.
Anyone else have that problem?
Or if you have a hard floor can you show me a pic of how its done?
Spencer54
Post
by Spencer54 » Tue Dec 02, 2014 1:45 pm
I think I'm almost there - I had a go this weekend but I was put off by being able to see the ply or at least the metal of the base of the original step.
Looking at yours, you can see that - so maybe mines right.
How much of the lip did you trim off mine seems high and that the door for where the Jack lives looks like it won't go on.
Now that everything is now 24mm higher (2x12mm ply).
Have I ballsed up putting it that high?
Dodgey
Post
by Dodgey » Thu Dec 04, 2014 5:51 pm
In a word, yes
- Well, sort of, you will be able to find a solution.
I used one sheet of ply (can't remember the thickness). Cetainly not two. My ply rested on ply offcuts but this only raised it a little as teh offcuts sat in the depressions in the floor.
When I trimmed the step It was the top outer edges I had to cut back a little, as raising the step just meant it would no longer fit. I also remember having to remove all of the plastic "webbing" on the underside of the plastic step as this was in the way too. None of it was tricky, especially with an electric finger file which makes short work of it.
Having the metal step visible (and the ply underneath) is a non issue. You wont' notice it or look at it ever again!
Spencer54
Post
by Spencer54 » Thu Dec 04, 2014 9:31 pm
Ive used a grinder and taken the webbing off the bottom - so hopefully that'll lower it a bit.
Toying with taking some off the lip as well.
Dodgey
Post
by Dodgey » Fri Dec 05, 2014 12:32 pm
Spencer54 wrote:Ive used a grinder and taken the webbing off the bottom - so hopefully that'll lower it a bit.
That rings bells to me. I may have done that too.
Spencer54
Post
by Spencer54 » Wed Dec 10, 2014 2:52 pm
Step on but door seems to be not shutting 100% and I can see daylight at the bottom seal - so I've missed something or the step is too proud.
Grinding off the webbing worked a treat and the height is now spot on though.
Mark Elvin
- Tribal Elder
Post
by Mark Elvin » Fri Jan 02, 2015 6:21 pm
Can anybody remember how much ply they bought to di their floor? Just started on the strip down today ready for flooring & re-spray.
billymansell
Post
by billymansell » Fri Jan 02, 2015 7:47 pm
An 8' x 4' sheet will do the floor with the offcuts used for some of the under-floor blocks as two thicknesses of blocks required for a level floor.
I had the diy shop cut the board in half so I could transport it.
The all black 2.5 V6 - "looks more like a pimpmobile than a playbus"
Mark Elvin
- Tribal Elder
Post
by Mark Elvin » Mon Jan 19, 2015 4:34 pm
Actually started mine at the weekend, cutting lots of 15mm thick packers to go in the lower ribs of the floor.
I had 1/2 a large sheet of 15mm cut into 25mm wide strips, I just use the tenon saw to cut then to length. Where the small high points are I saw down through a ply or two the chisel out the ply to clear.
Mark Elvin
- Tribal Elder
Post
by Mark Elvin » Tue Jan 20, 2015 7:37 am
I'll update the thread with my experiences of doing my floor, currently a work in progress.
25mm wide x 15mm thick marine ply strips bonded to low points of floor using Sikaflex.
Notched out to clear the ridges in some of the low points.
Same in the front area of floor. Some of the tar based insulation had to be scraped away to give a flat surface.
Along the step edge I clamped the baton & the step lip together to ensure a good bond. May pop a couple of small dome headself tappers in from underneath also as this area of the floor is largely unsupported.
daveblueozzie
Post
by daveblueozzie » Tue Jan 20, 2015 6:39 pm
Think about leaving a hatch to get to the fuel tank, earth wire problems or even sender unit, easier than dropping the tank.
Lost without my Bongo.
dobby
Post
by dobby » Tue Jan 20, 2015 8:45 pm
And it's got to be worth waxoyling the arches before the trim panel goes on?
Gasy
Post
by Gasy » Tue Jan 20, 2015 9:27 pm
Just what I was thinking as I was looking at them pics
Easy to do inside and in all them little holes
I've just used some interior stuff from lidl/aldi that was good really runny came with a 10" straw
Made by MAGNUS
Mark Elvin
- Tribal Elder
Post
by Mark Elvin » Wed Jan 21, 2015 7:26 am
daveblueozzie wrote:Think about leaving a hatch to get to the fuel tank, earth wire problems or even sender unit, easier than dropping the tank.
It's straight in the body shop after the floor is down to get the arches done, refitting the trim is being done after the arches are sortaed for this very reason!
dobby wrote:And it's got to be worth waxoyling the arches before the trim panel goes on?
I already have a TIG welded picture frame to go around the removable hatch made up.
dannyn
- Apprentice Bongonaut
Post
by dannyn » Mon Jun 22, 2015 10:04 pm
Just started this, stripped out the van, removed the blinds so the Boss can put blackout fabric on.
Now to start the
flooring, but first it needs to go see my mechanic friend for some sticking plasters after being nibbled by t
he tin worm
