Understand why my
Pela took so long to remove sump oil,after oil change I cleaned the
pump with a 6 litre
mixture of muc-off bike cleaner & water in a bucket and then operated the
pump, it emptied the bucket PDQ, the advantage of using water was that you can hear the water trickling into the container & when the trickle stopped re-
pump the
pela, I had to do this 5 times, there was no instructions in the box only instructions on the outside instructing to
pump the
pela only up to 20 times. Thanks to missfixit for educating me in the art of
pela use & and the neccessity of frequent re-pumping
will now use it out again when changing gearbox/powersteering/atf fluids.
There are no strangers here - only friends we have yet to meet.
