Post
by teenmal » Wed Dec 17, 2008 5:58 pm
dandywarhol wrote:There was a post about the
oil light last month and I can now report that the
oil light on the dash is both a pressure AND
level light. The sensor for the
level is in the sump.
I disconnected the wire and earthed it out whilst the engine was running - the
oil light came on!
Well done Dandy,could this be connected to Hydens TM2 if we could find out the wiring,to give audible warning??
Mal..
dandywarhol
Post
by dandywarhol » Wed Dec 17, 2008 6:16 pm
teenmal wrote:dandywarhol wrote:There was a post about the
oil light came on!
Mal..
Aye - could do - I was thinking of wiring it to my invertor and feeding 240v into my seat base to give me a jolt up the arse if I forgot to check the
level................
jaylee
Post
by jaylee » Wed Dec 17, 2008 8:21 pm
helen&tony wrote:Hi
Very useful...especially if you play with your pump, Kirsty, and tell us when the bells and whistles go off. Now, how many other lamps have 2 functions...I'll write them down so I don't forget, and keep it in the glove box....i'm SERIOUS...the old forgettory works too well at my age....so PLEASE ... can someone list those lamps!!!
Here's one..
The door open warning
light also tells you if the courtesy
light is on in the cab!!
Unless the courtesy lamp is switched off.. In which case the warning
light alerts you to that too..
Neat!!
ICB
Post
by ICB » Wed Dec 17, 2008 8:21 pm
Good to know, and reassuring, thanks dandy
Now if we can just work out all the different reasons the coil/scavenger fan warning
light flashes...(perhaps that's already been done and I missed it)
tomsk
Post
by tomsk » Wed Dec 17, 2008 8:46 pm
Thanks Dandy.
Tom
Post
by haydn callow » Thu Dec 18, 2008 10:06 am
oil light came on!
Mal..
I already have the TM-2 wired into the
oil pressure wire. It would be simple to add the
level wire. Just splice another wire into it and connect to the unit.
