silicone hose leaks, turbo clamp, & thermostat problems
Re: silicone hose leaks, turbo clamp, & thermostat problems
sounds like after after about 12 months of constant presure they seem to be streching the clips, so maybe it might be wise after 12 months that they are all tightened, then checked regular as this seems to be happening alot from what ive gathered over the last couple of months.
It will be interesting to see if some different clips cures the problem for future silcon hose replacements
It is more likely that the silicone rubber is 'extruding' - same idea as how you squeeze toothpaste out of a tube, the longer and hotter silicone is kept, the more likely is its to extrude, so the rubber is squeezed out from under the clip and this is reducing the clamping pressure, hence leading to leaks.waycar8 wrote:sounds like after after about 12 months of constant presure they seem to be streching the clips, so maybe it might be wise after 12 months that they are all tightened, then checked regular as this seems to be happening alot from what ive gathered over the last couple of months.
(So a question for the cooling system experts with silicone hoses, have you had any more slow leaks on the 'hot' or 'cold' side of the cooling system?)
This is where constant pressure clamps will have an advantage, as they will adjust to compensate.
There are new all plastic clamps on sale in the USA, basically they look like a band of plastic which is heat shrunk onto the hose, they are wider than normal clips, plus they are claimed to adjust for expansion/contraction. (Please note that they quote 40 F as a temperature below which cold leaks start, if only it was that hot here!)
http://www.gates.com/brochure.cfm?broch ... ion_id=546
- brorabongo
Suppose to be fitting my silicone hoses tomorrow.......starting to worry about them now.
Donald, just check the coolant level regularly and you will be fine, and think of the Champions League!
deffo the hot side,particularly the heater loop,both back and front heaters,also the top hose,
which makes sense as its the hottest ,after reading the above,never known a leak on the cold side,bottm hose etc.
anyone know what 40 deg f is in old money??
al & chris
- Tribal Elder
The last two hoses of ours to start leaking are the big bottom radiator hose and a long thin hose on underside of bongo behind drivers door.
40 f is about 5 c.
Mine was leaking on bottom hose into stat & that was the clip that went, also had other weeps on heater returns etc. so I don't think it makes a massive difference. Could start a whole debate on why there isn't really a cold side as such, but it's not too relevant to this & I can't be bothered
- brorabongo
I always check on my levels.......well every time I top up the screenwash I check.munroman wrote:Donald, just check the coolant level regularly and you will be fine, and think of the Champions League!
low coolant alarm does it the rest of the time for me.
i know what you say about the cold side kirsty,i was thinking colder side
thanks for the conversion into old money! thats a relatively high temp isnt it,no wonder the clips/hoses have been working hard to seal!
hows the lecy gadget doing?
- daveblueozzie
Slightly off topic but a rough idea on converting temp.
example 70f deduct 30 =40 then half the figure that's left =20c
example 40f -30 =10 by half =5c.
(or vise versa)
(or vise versa)
Lost without my Bongo.
thanks dave
ill stick to spanners and stuff its easier to ask
This is worrying as some of mine are starting to leak and are over a year and a half old now. The bottom rad hose and the top engine hose, have given them a tighten and seem ok at the moment.munroman wrote:It is more likely that the silicone rubber is 'extruding' - same idea as how you squeeze toothpaste out of a tube, the longer and hotter silicone is kept, the more likely is its to extrude, so the rubber is squeezed out from under the clip and this is reducing the clamping pressure, hence leading to leaks.waycar8 wrote:sounds like after after about 12 months of constant presure they seem to be streching the clips, so maybe it might be wise after 12 months that they are all tightened, then checked regular as this seems to be happening alot from what ive gathered over the last couple of months.
Could these also be the answer http://www.norma.net.au/norma-constant- ... lamps.html
F Zappa
F Zappa
they could be the answer!!you could be the test pilot on these.
there are plenty of constant pressure clips available but most of them are expensive,2 clips per hose and all that.
Yes, they look good, and Norma are a good brand, and a good illustration on the webpage as to how much expansion/contraction there can be.lizard wrote:This is worrying as some of mine are starting to leak and are over a year and a half old now. The bottom rad hose and the top engine hose, have given them a tighten and seem ok at the moment.munroman wrote:It is more likely that the silicone rubber is 'extruding' - same idea as how you squeeze toothpaste out of a tube, the longer and hotter silicone is kept, the more likely is its to extrude, so the rubber is squeezed out from under the clip and this is reducing the clamping pressure, hence leading to leaks.waycar8 wrote:sounds like after after about 12 months of constant presure they seem to be streching the clips, so maybe it might be wise after 12 months that they are all tightened, then checked regular as this seems to be happening alot from what ive gathered over the last couple of months.
