dandywarhol
Post
by dandywarhol » Thu Nov 13, 2008 3:54 pm
emma & ian wrote:I'll move it to the back and see if it makes any difference, thanks for your help.
I don't think it'll make a jot of difference until the temperature gets into the sub zeros
Post
by teenmal » Thu Nov 13, 2008 4:21 pm
Hi,Is this not for the air recirculation(recycle of cabin air)prevents exhaust fumes etc from entering the cabin when in heavy trafic.The flap being controled from the slide on the heater control panel.
Cheers mal..
Richard D
Post
by Richard D » Thu Nov 13, 2008 6:24 pm
Mines a 95 without climate control and I've got nothing like that
smoke me a kipper i'll be back for breakfast
dandywarhol
Post
by dandywarhol » Fri Nov 14, 2008 12:35 am
teenmal wrote:Hi,Is this not for the air recirculation(recycle of cabin air)prevents exhaust fumes etc from entering the cabin when in heavy trafic.The flap being controled from the slide on the heater control panel.
Cheers mal..
Nope teen
- Mine's an analogue heating '96 and from the south of Japan - doesn't have that gizmo either Richard D
Post
by teenmal » Fri Nov 14, 2008 11:07 am
dandywarhol wrote:teenmal wrote:Hi,Is this not for the air recirculation(recycle of cabin air)prevents exhaust fumes etc from entering the cabin when in heavy trafic.The flap being controled from the slide on the heater control panel.
Cheers mal..
Nope teen
Hi dandy,does your van have the recirculation feature,ie the sliding control on the dash?Its got the emblem of a car with a U turn arrow.?
Mal..
dandywarhol
Post
by dandywarhol » Fri Nov 14, 2008 1:24 pm
Yep - it closes off the flap at the inside of the baulkhead if I can remember
spout
Post
by spout » Tue Nov 25, 2008 6:33 pm
I had the cowling off today and remembered this thread so took some photos. But I can't seem to post them.
There are infact two flaps operated by the
lever, both opening and closing together (see unattached photos
). With the flaps closed air is drawn up from the engine bay, not fresh from the front.
manners
Post
by manners » Tue Nov 25, 2008 6:48 pm
In the old days iam sure you all remember
the intake on the air filter box ( the ones shaped like a frying pan) had
winter and summer settings pointed down for summer and up for
winter drawing in warmer air to stop iceing in the carb, think its a similar thing but probably not needed in this country on injection systems. Cooler air is better for performance for the V6ers anyway
not sure about oil burners
scanner
Post
by scanner » Tue Nov 25, 2008 6:58 pm
manners wrote:In the old days iam sure you all remember
Cooler air is better for all engines as it's denser, why do you think TD's have intercoolers?
Only wimpy petrol engines needed to have it warmed up for them, so they didn't catch a cold until the carb was warmed up.
dandywarhol
Post
by dandywarhol » Tue Nov 25, 2008 7:32 pm
.......only wimpy petrol engines with carbs and single point injection use hot air intakes - so that rules out just about every wimpy petrol engine in the last 10 years.
manners
Post
by manners » Tue Nov 25, 2008 7:48 pm
scanner wrote:manners wrote:In the old days iam sure you all remember
My 2.5 turbo Impreza has an intercooler
but there's nowt wimpy about that petrol engine
Post
by francophile1947 » Tue Nov 25, 2008 7:51 pm
manners wrote:My 2.5 turbo Impreza has an intercooler
It hasn't got a carburettor either.
manners
Post
by manners » Tue Nov 25, 2008 7:56 pm
francophile1947 wrote:manners wrote:My 2.5 turbo Impreza has an intercooler
Never said it had
scanner
Post
by scanner » Tue Nov 25, 2008 8:02 pm
manners wrote:francophile1947 wrote:manners wrote:My 2.5 turbo Impreza has an intercooler
Never said it had
Neither did I.
I was on about the ones with carburetors that turned into a block of ice every time you put your foot down on a cold morning. The poor dears needed warming with hot air before they would wake up and take you to work.
Latent heat of evaporation and all that.........
manners
Post
by manners » Tue Nov 25, 2008 8:20 pm
Ahh the days when diesel used to freeze solid in the tank and you used to have to light a fire under them
