cheers manners
Bad Vibrations!
manners
Bad Vibrations!
When reaching the late 60's mph my Freda starts to vibrate but not the steering wheel? the doors get such a rhythm going that they come away from the top seal about 5mm the sat nav on the front window starts to wobble i can even feel it through the seat. when i reach 80 it calms down a bit (tested on private track
) any ideas could it be something to do with the prop or drive shafts?
cheers manners
cheers manners
trevd01
manners
trevd01
Still worth getting the wheel balance checked, I would have thought - it is likely to be a much cheaper option than anything more serious to do with drive shaft joints, etc.
As I said we had to have ours re-balanced - in our case despite new tyres and new weights.
- dreamwarrioruk
kawasaki kid
- Tribal Elder
Get your wheels balanced and your tracking checked at the same time as I had the same problem and ended up getting both done to solve the problem, are you running on steel or alloys
as some after market alloys can be a nightmare to balance.
If I had all the money I ever spent on my Freda ............ I`d spend it on my Freda.
- dandywarhol
I've always found the stud hole method better dreamer..........they seem to be perfectly concentric - the centre isn't guaranteed to bedreamwarrioruk wrote:the wheels need to be balanced by the centre hub and not by the studs.ours had the same problem but it went straight after i got them rebalanced properly
- dreamwarrioruk
Ame
Wheel wobble
I have 18" alloys (fitted when i bought it) and have had them balanced twice and the tracking checked.
Still at 60mph I feel a wobble.
Can anyone give further details on the importance of the 'central hub' fitting?
Is it possible to buy/fit spacers to ensure a good fit?
Cheers, Ames
Pz
Cheers, Ames
Pz
- westonwarrior
john and jue
