1) My manual refers to an NE sensor. What does NE stand for and what does it do?
2) As I press the throttle and measure the throttle position sensor at 2.15v and small ticking sound starts like a small pump or something. As I press the throttle further the noise continues until about 3.15v when it stops. What could it be?
3) What is the throttle sensor compensation resistor for?
4) I measured said resistor and got a reading of about 840 ohms. The manual says it should be 0.1 ~ 2.5 ohms. Obviously that's a significant differernce but could it be a typo (missing k perhaps)? Would a couple of kind souls be prepared to measure theirs so we can see work out if the book is right or whether I've got a lemon.
To measure the resistance open the drivers seat and locate the snesor block in the following pic
Take it apart and measure between pins "D" and "F". In the following picture that's the two central pins in the the bottom row of the socket.
Thanks in advance
