webcam
Moderator: Ian
webcam
had a thought for next year.......
but don't know if it would be possible or feasible....
but if someone was to set up a webcam at one end of the field, say down near the marquee, on a pole, and set it up early... say wednesday
and it pointed down the field, if it did a capture every hour or two.....
anyone not at the bash, or even those going later or for the day could check the site, what was going on etc.....
just a thought.....
just a thought.....
- B*Witched Blingo
Re: webcam
What a blummin good idea..
If Most Haunted can do....Hopefully a super techie person could check out server stuff etc....
You Tube Films Click Here
- missfixit70
Re: webcam
Corking idea one for each field I reckon
Re: webcam
What a stunning idea
Now, should access be Members Area only.
Discuss.
I'll get me coat and get out the room quick
Discuss.
Re: webcam
John the sparky wrote:had a thought for next year.......
just a thought.....
Just like Big ruddy Brother!!!
- missfixit70
Re: webcam
Just don't let Mike in there or no-one else'll get a look in Only joking mike
Re: webcam
Over the river to spot the skinny dippers?
Re: webcam
\ssdo[awwrfnrfv rvzdjc ;zdhcvox8cuvs90d]vj\sdv\ varefmWE FWDV\SDV\SDVI\SDPOFI\SDOF\SDFJMwef DCV\SCMV \CPV.........missfixit70 wrote:Just don't let Mike in there or no-one else'll get a look in Only joking mike
wot? somebody speak? No?
ssedfwe02jnng \[fovj\sifuj2p'5p9rti3p4tignml' vlkc mc m ijv'prgwerwnefwefwerweori
Re: webcam
thats a fantastic idea, if only id known, had the lappy with me all weekend with built in webcam
ooops runs before i get kicked in the butt
Simplezzzzz
Re: webcam
Are you speaking the l33t again Mike d00d?mikeonb4c wrote:\ssdo[awwrfnrfv rvzdjc ;zdhcvox8cuvs90d]vj\sdv\ varefmWE FWDV\SDV\SDVI\SDPOFI\SDOF\SDFJMwef DCV\SCMV \CPV.........missfixit70 wrote:Just don't let Mike in there or no-one else'll get a look in Only joking mike
I think I might have just the equipment for this (and server stuff), we'd just need a reliable power source
Re: webcam
Me? If it'll run on hot airHotpot wrote:we'd just need a reliable power source
- missfixit70
Re: webcam
I'm sure you'd be able to rig up something off a hookup or from the toilet block area if you were to put it up that way? Or if you wanted it in the nonhookup field would it be able to run off LB's in rotation which then get charged from the hook up side? How much power would it need?Hotpot wrote:Are you speaking the l33t again Mike d00d?mikeonb4c wrote:\ssdo[awwrfnrfv rvzdjc ;zdhcvox8cuvs90d]vj\sdv\ varefmWE FWDV\SDV\SDVI\SDPOFI\SDOF\SDFJMwef DCV\SCMV \CPV.........missfixit70 wrote:Just don't let Mike in there or no-one else'll get a look in Only joking mike
Re: webcam
Sounds like a plan that Kirsty. All I can see we need to power for each point is a weatherproof IP camera and an internet enabled (via usb dongle probably) router. I've got 2 cameras that have infra red for nite time too which should be ok. No problem with server stuff either as that's located somewhere else. So not much power needed at all really just needs to be constant, sure between us with your electrical know how we could sort something out
Mike, I didn't think that was hot air, but geek speak, maybe I need to get out more
- missfixit70
Re: webcam
Just need to sort out a decent mast then I guess that means you'll have to get there early & be the last to leave - bummer
