Hi All,
Another hopefully easy question for you from a newish (very non technical!!) owner.
My stereo aerial lead has come unplugged from the aerial connector somewhere in the Bongo. Can anybody tell me where the connection could be found? Would it be in a standard place or could the connection be anywhere? I have looked at all the leads I can see but just can’t seem to find it.
Hope this is understandable!!
Cheers,
BongoDez.
Aerial Connections
BongoDez
Re: Aerial Connections
do you mean the coax has come out of the plug?, or that the whole aerial has come out the back of the stereo?
the bongo aerial comes out of the back of the stereo and over the drivers footwell up the windscreen/door pillar, it actually has a extension peice in so it might have come apart at that point.
cant remember its exact location but i think its just at the top of the drivers footwell before it goes behind the door pillar trim (door hinge side)
BongoDez
Hi there,
I did mean the coax has come out of the plug.
The cable length did suggest its around that area and thats where I was looking but couldn't see an obvious connector.
I'll have another check in the morning.
Cheers, BD
Cheers, BD
ha............so is the aerial still pligged into the back of the stereo? and the other end has the connector missing?
if so it will probably still connected to the other end of the coax that goes up the door pillar
BongoDez
Yep, the aerial is plugged into the stereo, its the other end that’s not connected.
Do you know if the coax will be hanging out of the end of the door pillar?
oh and thanks for deciphering my cryptic questions!!
Cheers,
BD
Cheers,
BD
BongoDez wrote:Yep, the aerial is plugged into the stereo, its the other end that’s not connected.
Cheers,
BD
BongoDez
Thanks for your help waycar8, I'll let you know how I get on tomorrow.
Cheers,
BD.
Cheers,
BD.
