Cooling system diagram
Re: Cooling system diagram
Post by missfixit70 » Fri Nov 06, 2009 7:53 pm
Looking on lushprojects - http://www.lushprojects.com/bongopartsm ... mgno=.html - I'd say pointy end down, disc end up.
If it was disc end down, the disc is doing nothing that the thermostat itself isn't already doing, I think?
dandywarhol
Post by dandywarhol » Fri Nov 06, 2009 8:33 pm
Agreed Kirsty but I really want to know for definite............ :)
haydn callow
Post by haydn callow » Fri Nov 06, 2009 8:46 pm
Where's Allan when you need him ???......give him a dig Doone !!! Thanks
http://www.coolantalarm.co.uk
Also BMW Clocks
widdowson2008
Post by widdowson2008 » Fri Nov 06, 2009 9:13 pm
dandywarhol wrote:Agreed Kirsty but I really want to know for definite............ :)
If the diagram in Kirstys post is correct, then the pointed end is DEFINITELY pointing downward, with the end showing the spring uppermost.
The photo in Dandys post showing the thermostat (courtesy of Bongobits) is basically upside down.
The only way it can be the other way up is for the Japs to have got the diagram wrong.
Pointed it out several posts ago - it was overlooked.
Steve
mikexgough
Post by mikexgough » Fri Nov 06, 2009 9:20 pm
Which makes sense as the temperature sensing "bulb" of the Thermometer is between the spring in the "pointy" end......therefore in the coolant flow return from the radiator......so it can start to open at the predetermined temperature and pressure...
haydn callow
Post by haydn callow » Fri Nov 06, 2009 10:41 pm
Woooop's gonna think again...photo's to follow
Imagethat's my stat removed last week...It fell out and I don't remember which way round it was for sure....the new one would only go one way.
However...I think it goes the way it is in the photo.....co's...there is a white limescale deposit all over the top surface and the bottom below the seal is clean brass.....that is what I would expect if it sits as in the photo
Also BMW Clocks
Post by Doone » Fri Nov 06, 2009 10:54 pm
Can anybody postively confirm the pointy end of the thermostat points down into the thermostat cover?
He's home now. :D I have asked him about the thermostat and he said the pointy end points down.
The disc end goes up into the thermostat housing.
There's a 'lump' on the rubber seal of the thermostat and this points towards the drivers door.
Haydn, that must mean that it's upside down in your photo, as you have stood it on its flatter end. :)
Please note that Allan has not read through these posts and has not looked at the diagrams, so can't comment on them.
The Great Pretender
Post by The Great Pretender » Sat Nov 07, 2009 1:41 am
Locked threads widdowson................. Must have been caused by me............ :lol:
One of my first threads posted here was if the stat is an 82c one what temp does it open at? (As this is the temp the head should be held at. (It runs at 85c, modulating between 80 to 90c with the stat on the OUTLET of the head) So what temp would the head need to be at to return coolant above 82c?)
Answer 2 bloody hot.
If you want to find out what happens on the bottom hose put a temp sensor at each end. That will supprise you, you then need to find out how the internal flow affects the system.
To infinity and beyond
widdowson2008
Post by widdowson2008 » Sat Nov 07, 2009 8:29 am
So the Japs did get it right in their diagram after all. :D
Steve
mikexgough
Post by mikexgough » Sat Nov 07, 2009 8:31 am
This article might help folks have an understanding of a thermostat on the return side of a cooling system...... it is for a Lotus Elise using a K-series engine (which were notorious for Head gasket failure) however, ignore the K series solution to prevent HGF and just focus on the theory of how such a system works and the progressive opening of the thermostat http://web.tiscali.it/elise_s1/index.htm
widdowson2008
Post by widdowson2008 » Sat Nov 07, 2009 8:57 am
The Great Pretender wrote:Locked threads widdowson................. Must have been caused by me............ :lol:
I read through that post (marathon job :wink: ) and gleaned quite a lot from it. Take out the 'handbags at dawn' stuff and the numerous diversions, it made very interesting reading.
One thing it did highlight, and this one is showing similar signs, is that no one really is 100% sure how the system works in the finer detail. But I think it is only the finer detail where folk are disagreeing.
Going back to object of the excercise, from my perspective, all I am trying to get out of this is an accurate diagram which I can print out, take to the van, and and check things out.
Steve
mikexgough
Post by mikexgough » Sat Nov 07, 2009 11:18 am
this might help.......to show how a thermostat opens at different temperatures - IMHO and I'm prepared to be shot at dawn....... the only real effective bleed is at the 98c setting......BUT how many owners bleed the system at that point........ you have to wonder that of you bleed when the thermostat just opens.....do you in effect clear all of the air from the system.......
I'll book the wall now....... and bring my own blindfold....... :lol: :lol:
widdowson2008
Post by widdowson2008 » Sat Nov 07, 2009 11:38 am
mikexgough wrote:This article might help folks have an understanding of a thermostat on the return side of a cooling system...... it is for a Lotus Elise using a K-series engine (which were notorious for Head gasket failure) however, ignore the K series solution to prevent HGF and just focus on the theory of how such a system works and the progressive opening of the thermostat http://web.tiscali.it/elise_s1/index.htm
Just read through your link. I think I can actually see light at the end of this tunnel. (thermostat/bypass wise at least)
With the exception of the expansion tank involvement, this (to me) looks a very similar circuit to the Bongo one in my (limited) understanding.
.......and just seen your very latest re:thermostat. This thinking makes sense.
Move over and make space at the wall (I will not need the blindfold cos I'm in the dark anyway - but learning all the time)
Steve
miker
Post by miker » Sat Nov 07, 2009 11:50 am
To answer a point that seems to be made quite often on this forum and was made early on in this thread, and happy to join the queue at the wall if I'm wrong, but the comment about bottom hose of the rad being cool while top is hot - surely this means the rad is doing its job.ie. cooling the fluid passing through it. That of course assumes the coolant flows from top of rad to bottom.
mikexgough
Post by mikexgough » Sat Nov 07, 2009 11:57 am
miker wrote:To answer a point that seems to be made quite often on this forum and was made early on in this thread, and happy to join the queue at the wall if I'm wrong, but the comment about bottom hose of the rad being cool while top is hot - surely this means the rad is doing its job.ie. cooling the fluid passing through it. That of course assumes the coolant flows from top of rad to bottom.
=D> =D> =D>
