Good thinking, IMHO. As above, you can trust Ian Taylor (Market Drayton, Shropshire), or if you fancy a holiday in the south west, Allans in Plymouth is apparently a whizz with them - good time to go down that way is end of May, and continue on into Cornwall. Give or take a day or two, the basking sharks return, off Sennen Cove for example, on 28 May each year, and there are trips out to see them.Grahame at work wrote:So as I was planning on getting mine done in the spring - does anyone know of a garage that HAS done a V6 cam belt change?
successfully![]()
Following on from the recent postings in this thread - I'd probably be prepared to travel a LOOONNNNNNGGGGG way to a garage that I felt OK with.
Regards Grahame
v6 cambelt change
Re: v6 cambelt change
Grahame at work
Thanks for the suggestions
Although we would like to do Cornwall it is not on our plans for next year.
However, we go to Shrewsbury several times a year and I know Ian Taylor as we got our first Bongo from him - and yes I trust him.
So it looks as though I may arrange something with him for early next year.
Regards Grahame
Regards Grahame
