my back squirter aint working but the wiper is, does this mean that its not a fuse problem?
I have checked the hole and there's no obstruction and there is no sound like it's trying to squirt. I am thinking it may be the pump? any ideas?
Hmmm, that's how I know when it's time to fill up againfrancophile1947 wrote:Is bottle full? Rear washer outlet is higher than the front, so it sometimes doesn't work whilst the front does. Both pumps are on the washer bottle at the front.
hmmm... where did you get a spare pump from then or is there equivalents that will work?You've Been Bongod wrote:mine was the same changed the pump on washer bottle now working
Sluggy wrote:hmmm... where did you get a spare pump from then or is there equivalents that will work?You've Been Bongod wrote:mine was the same changed the pump on washer bottle now working
