wing off, cause you just know the source of the problem is going to be on the backside of the wing.
wing from visible side.
from inside.cleaned up wing and treated with rust ihhibitor.
currently at this stage
what im going to do,in hindsight,is flat off the rest of the lower half of the wing and respray
all of the silver bit so hopefully it will all blend in.while the wings off im also going to blast some more waxoyl behind the wing and the panel on the van.off to do some more sanding and painting catch you later, tay.
