where do I put the gear box oil?
banga
Veg_Ian
Ok I won't say in the gearbox. (Oh b*gger I just did).
You have to pour it through the dipstick tube. Daft I know but there you are. If topping up then you can buy 1 litre bottles of Dexron III with a flexible tube on the cap. However, it's more economical to buy a 5 litre tin from your local factors because at some point you should be changing the lot.
Hook up a piece of tubing that will fit inside the dipstick tube (the kind of plastic tuning you would use to bleed the brakes) with a small funnel and slowly add the ATF. Incidentally, the correct way to read the level is with the vehicle level, with the engine hot and after changing the gears a few times.
banga
Thankyou!
Note to diary ...listen to husband more !
Thanks again for your help.
AliBongo
