I'm no gearbox expert whatsoever, but just had a rummage on lushprojects
What about the lock up control valve & lock up sleeve, parts 21-283 & 21-241 on this one - http://www.lushprojects.com/bongopartsm ... 02.html#69
Or the inhibitor switch 19-444 here - http://www.lushprojects.com/bongopartsm ... 1of03.html
Also crops up again here - http://www.lushprojects.com/bongopartsm ... o=.html#17
Obviously you'd have to check the drawings are the right year/model/engine for yours & it might be a load of rubbish, but worth an hour or two's investigation?
http://www.lushprojects.com/bongopartsmk2/
Or check out the wiring diagrams - http://www.g8dhe.net/bwm/bwmanualp.htm?1997/Page_90
Need an automatic gearbox expert
- missfixit70
Re: Need an automatic gearbox expert
gerandsam
Over my head sorry, but it is a four wheel drive Bongo. I will make a list of these possibilities and those in the other post and raise them with the new transmission guy.missfixit70 wrote:Did anyone track down where/what the "ATF thermostat sensor" is that supplies the signal for the ATF oil temp to the ecu, pin 2J? Just thinking a 15 year old temp sender immersed in ATF, may have given up the ghost as a lot of water temp senders seem to?
Just looking in the manual, seems there's three different autoboxes, the J5-DE, the WL-T (2WD) & the WL-T(4WD), any idea which one it is that has this problem? Can't find anything that points at the temp sensor (if there is one?)
- missfixit70
If you do get a resolution to this, try & get as much detail out of them as possible as to what it was & get the old parts so you can tell/show others that may have the same issues
