broken rear wash hose
Barley 1981
Post by Barley 1981 » Thu Jul 29, 2010 7:57 pm
the hose which squirts the rear wash-wipe has snapped somehow and I now have water going into the door cracks when using the rear wash-wipe, I have tried joining the pipes with tape (2 different types) does anyone have any suggestions on how to fix it? thanks
Re: broken rear wash hose
Post by missfixit70 » Thu Jul 29, 2010 8:03 pm
Should be able to repair it with standard bits available from Halfrauds or any motor factor, this may help - http://www.lushprojects.com/bongopartsm ... mgno=.html
This has come up on the forum quite a few times before.
Barley 1981
Post by Barley 1981 » Thu Jul 29, 2010 8:12 pm
Thanks Kirsty, Are you thinking that a piece of hose over the top of the split? it is the bit between the grommits that fit to the boot/car and it is the plastic tube thingy inside the rubber pipe that has snapped.....hard to explain without a photo I suppose! thanks for help again :)
Post by missfixit70 » Thu Jul 29, 2010 8:19 pm
I was thinking replace the broken bits :? its basically just connectors & hose.
Barley 1981
Post by Barley 1981 » Thu Jul 29, 2010 8:21 pm
do you think this is the correct size 4mm??
http://cgi.ebay.co.uk/Non-Return-Connec ... 335f5116ee
Post by missfixit70 » Thu Jul 29, 2010 8:27 pm
Don't know, I'd go & measure what's on there to make sure.
Scott
Post by Scott » Fri Jul 30, 2010 1:26 pm
Make clean cuts on both ends of the pipe, and if the pipes are tight then heat them up with a hairdryer to make them pliable, you can also find a good selection of joiners, Tees and tube at most pet shops, fish tank piping is normally fine :wink:
The user formerly known as csmcqueen ;)
スコット
