Diesel fuel filter
Diesel fuel filter
Hi, can anyone tell me if when replacing the fuel filter on a diesel bongo (1995) do you fill up the new filter with fresh diesel before fitting. Thanks.
Re: Diesel fuel filter
P.S. I have looked at the instructions on the members area but it doesn't say there
You dont have to but you'll find your car will stall after 30 secs and take a bit of cranking,usually standard procedure to fill the new filter with injector cleaner so it gives them a pure dose of cleaner, if not then just put some clean diesel in.
Julian
Julian
- daveblueozzie
I agree321Away wrote:You dont have to but you'll find your car will stall after 30 secs and take a bit of cranking,usually standard procedure to fill the new filter with injector cleaner so it gives them a pure dose of cleaner, if not then just put some clean diesel in.
Julian
Lost without my Bongo.
Thanks fella's any particular brand of injector cleaner recommended or will any stuff do the trick?
- daveblueozzie
Redex, Wynns, STP. doesn't really matter they all do about the same job, just make sure you buy for diesel not petrolOldboybob wrote:Thanks fella's any particular brand of injector cleaner recommended or will any stuff do the trick?
Cheers Dave will do that tomorrow
