Driving Lights
malabar
Driving Lights
Post by malabar » Sat Feb 26, 2011 12:41 pm
Help needed please. Our driving lights are either on very low dipped, or we have to use full beam. How do we raise the pitch of the lights to drive safely. We are off to France 6th March, and fixing deflectors as well. Thanks a lot. Malabar.
Re: Driving Lights
Post by bigdaddycain » Sat Feb 26, 2011 1:00 pm
Have you tried fiddling with the plugs to the actual bulbs whilst they are switched on? Sometimes the plugs "go loose" (though they feel tight), and a good earth is needed for a continuous good light... Some bongo's have "auto dip" switches fitted too... Is there any aftermarket rocker switches in the cabin that are (on the surface) apparently redundant? Try flicking any spurious switches with the lights on to see if there is any difference... :wink:
rita
Re: Driving Lights
Post by rita » Sat Feb 26, 2011 1:08 pm
Hi malabar,
If you take your vehicle to a garage with a Beam Setter they will test your setting and adjust if required,then you know your lights are Legal.
They can also test the strength of the light.
Cheers..
Re: Driving Lights
Post by bigdaddycain » Sat Feb 26, 2011 2:18 pm
"very low dipped" Aha! I see! (thanks rita) I read that as low light output... #-o
