Oil Leak
Milly
Oil Leak
Post by Milly » Mon Aug 29, 2011 9:25 pm
I have a small oil leak coming from the bottom of cylinder head on drivers side. Any ideas how to fix!!
M 80NGO
Location: Usually in My own wibbly wobbly lill world ! Otherwise Huntingdon.
Re: Oil Leak
Post by M 80NGO » Mon Aug 29, 2011 9:28 pm
Can you actually see where its coming out of the cylinder head, is it defo the cylinder head or is it the rocker / cam cover ?
Re: Oil Leak
Post by missfixit70 » Mon Aug 29, 2011 9:29 pm
Are you sure it's coming from the cylinder head & not the rocker cover gasket (may need replacing or may just need nipping up), or the air inlet manifold joint, the fuel pump or the steerring rack (& blowinig back)? Clean it all off & check where it's coming from, could be it's nowt to worry about, a lot of bongos have a little bit of oil in this area, more do than don't :wink:
Are you using a lot of engine oil?
Milly
Re: Oil Leak
Post by Milly » Mon Aug 29, 2011 9:42 pm
I've just taken another look at it and it appears to be coming from the bottom of cylinder head at the front of the engine, presume that this is close to the belts (cam/fan)
M 80NGO
Re: Oil Leak
Post by M 80NGO » Mon Aug 29, 2011 9:51 pm
My van ( 2.5 diesel) was in last month for an oil leak and it was a faulty camshaft oil seal it was quite a bad leak and was leaking down the front drivers side of the engine, a £4 seal cost me £280 to replace :cry:
Best thing to do is to get a 5 litre tin of brake and clutch cleaner and a spray bottle and give the engine a clean, just squirt the brake cleaner on and watch the crap run off this will give you a better idea of where the leak is.
Milly
Re: Oil Leak
Post by Milly » Mon Aug 29, 2011 9:56 pm
Thanks for that advice. I will give that ago!!
M 80NGO
Re: Oil Leak
Post by M 80NGO » Mon Aug 29, 2011 10:07 pm
Milly wrote:Thanks for that advice. I will give that ago!!
What your location there may be a bogolier near to you that can have a lill look, you may have to remove your under tray aand remove the material liner as mine was soaked in oil :roll:
Milly
Re: Oil Leak
Post by Milly » Mon Aug 29, 2011 10:11 pm
East Cheshire.
